By combining a microATX format with the Intel Xeon processors E3-1200 V3 family and all its latest technologies, this board is a versatile solution for SMBs and independent professionals to build affordable yet high performing systems within compact rack or tower enclosures. From a mainstream intranet system performing standard tasks like file or print serving, a web server dedicated to a low traffic websites, a basic engineering or content creation workstation, to the building block of a computing grid or a render farm, the possibilities offered by this model equal its performance capabilities and make it a perfect candidate for a high value acquisition.
The LAN controller built on those two motherboards feature several improvements over the previous generation that has been a long-time standard in the server market. In addition to overall performance and error correcting improvements, the power consumption has been reduced thanks to the on-chip integration of switching voltage regulators improving the efficiency of the power delivery to the controller. This controller also received audio/video bridging features, notably time-stamping and synchronization of time sensitive applications through traffic shaping, time-based transmission, and precision time-stamping. Two more management functions are also included, with the support of common transport for LAN-to-BMC / local OS-to-BMC and standards-based transport for BMC-to-adapter communication.
With the support of the latest PCI Express Gen.3.0 technology directly on the CPU, the GA-6LASH is fully configured to provide users with dramatically reduced latency and improved data bandwidth to get the most out of its expansion accessories. Red Hat Certified Hardware GIGABYTE certifies its server hardware with Red Hat Enterprise Linux to provide its customers with the confidence of knowing that their hardware systems are supported by Red Hat when they run Red Hat Enterprise Linux.
The VMware ready program allows customers to quickly identify products and solutions from VMware's partners, which are optimized for VMware vSphere. The VMware Ready logo certifies that this product addresses VMware's specific criteria in terms of integration and compatibility, and that it is ready to execute mission-critical applications and operations.
The power of Xeon on a compact board
By combining a microATX format with the Intel Xeon processors E3-1200 V3 family and all its latest technologies, this board is a versatile solution for SMBs and independent professionals to build affordable yet high performing systems within compact rack or tower enclosures. From a mainstream intranet system performing standard tasks like file or print serving, a web server dedicated to a low traffic websites, a basic engineering or content creation workstation, to the building block of a computing grid or a render farm, the possibilities offered by this model equal its performance capabilities and make it a perfect candidate for a high value acquisition. -
LAN controller
The LAN controller built on those two motherboards feature several improvements over the previous generation that has been a long-time standard in the server market. In addition to overall performance and error correcting improvements, the power consumption has been reduced thanks to the on-chip integration of switching voltage regulators improving the efficiency of the power delivery to the controller. This controller also received audio/video bridging features, notably time-stamping and synchronization of time sensitive applications through traffic shaping, time-based transmission, and precision time-stamping. Two more management functions are also included, with the support of common transport for LAN-to-BMC / local OS-to-BMC and standards-based transport for BMC-to-adapter communication. -
Support of PCIe generation 3.0
With the support of the latest PCI Express Gen.3.0 technology directly on the CPU, the GA-6LASH is fully configured to provide users with dramatically reduced latency and improved data bandwidth to get the most out of its expansion accessories. Red Hat Certified Hardware GIGABYTE certifies its server hardware with Red Hat Enterprise Linux to provide its customers with the confidence of knowing that their hardware systems are supported by Red Hat when they run Red Hat Enterprise Linux. -
VMware ready
- Gigabyte GA-6LASH - 1.0 - motherboard - micro ATX - LGA1150 Socket - C222
- Product Type
- Motherboard - micro ATX
- Chipset Type
- Intel C222
- Processor Socket
- 1 x LGA1150 Socket
- Compatible Processors
- Core i3, Xeon E3-1200 v3 series
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR3, ECC, unbuffered
- Storage Ports
- 2 x SATA-600 (RAID), 4 x SATA-300 (RAID)
- USB / FireWire Ports
- 6 x USB 2.0 + (1 x USB 3.0 via headers)
- Graphics
- ASPEED AST2300
- Audio
- HD Audio (8-channel)
- LAN
- 2 x Gigabit Ethernet
- Product Type
- Chipset Type
- Intel C222
- Processor Socket
- LGA1150 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz
- Supported RAM Integrity Check
- ECC
- Registered or Buffered
- Unbuffered
Graphics
- Graphics Controller
- ASPEED AST2300
Audio
- Audio Codec
- Realtek ALC892
- High Definition Audio, Dolby Home Theater
LAN
- Network Controller
- Intel I210-AT
- Network Interfaces
- Expansion Slots
- 4 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x8 (x4 mode) , 1 x PCIe 2.0 x4 (x1 mode) , 1 x CPU
- Storage Interfaces
- SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
- 1 x VGA , 1 x serial , 4 x USB 2.0 , 2 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
- Internal Interfaces
- 1 x serial - header , 1 x USB 3.0 - header , 2 x USB 2.0 - Type A
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
- IPMI 2.0 support
- Hardware Monitoring
- CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage
- Hardware Features
- Clear CMOS Button
- Included Accessories
- I/O back plate
- Cables Included
- 2 x Serial ATA cable
- 24.4 cm
- 24.4 cm
