Gigabyte ATI Radeon 7850 HD 975MHz 2GB PCI-Express 3.0 HDMI OC
Quicklinx: 7ZSSWS00 Mfr#: GV-R785OC-2GD
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
Using high quality components on graphics cards is the key factor for having a long lasting, stable and reliable product. GIGABYTE Ultra Durable 2 Edition graphics cards now feature a sophisticated layout topology. This state-of-the-art power design from GIGABYTE delivers the ideal integration of thermal, electric characteristics, digital signals, power circuitry and optimum placement of components for enhanced graphics performance.
  • Model Name GV-R785OC-2GD
  • GPU Radeon HD 7850 (Pitcairn PRO)
  • Core Clock 975 MHz (Std 860 MHz)
  • Memory Clock 4800 MHz
  • Memory Size 2048MB GDDR5
  • Bus Type PCI Express 3.0
  • Memory Bus 256-bit
  • Stream Processors 1024
  • Memory type 64Mx32
  • DirectX 11 Yes
  • DVI Port DVI-I
  • DisplayPort Yes (Mini DisplayPort*2)
  • HDMI HDMI 1.4a
  • HDCP Yes
  • 3D'Vantage P: 20446 / X: 10532
  • 3D`11 P: 5677 / X: 1762
  • Ultra Durable 2
  • Anti-turbulence cooling
    The special inclined dual fan design effectively minimizes the flow of turbulence between two fans and enhances heat dissipation of hot area right underneath each fan. By unique design, WINDFORCE 2X even enlarges air channel on the graphics card vents and creates a more effective air flow system in chassis. This special design helps heat dissipate quickly from GPU. In addition, WINDFORCE 2X is equipped with 2 copper heat-pipes which strengthen the speed of heat dissipation.
  • AMD Eyefinity technology
    Supporting multiple independent display outputs simultaneously, AMD Eyefinity technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience.
  • Cross Fire
    Multiply and Conquer with Multi-GPU Performance: CrossFire's "supertiling" GPU sharing speeds rendering by evenly dividing the graphics processing, intelligently alternating the rendering workload to each Radeon GPU for efficient load balancing, and optimized performance. CrossFire boosts image quality along with rendering speed, eliminating the need to crank down screen resolutions to get the high image quality you want. CrossFire supports a wide range of ATI-based graphics cards and motherboards, and offers compatibility with a broad array of third party components for a flexible and robust solution.
  • Avivo HD
    Avivo could provide vibrant high fidelity, flawlessly smooth next-generation video playback. Avivo technology easily allows your PCs to become digital home media center by its compelling video pipeline design that comprises the latest high definition video hardware acceleration, including H.264 and WMV9.
Gigabyte GV-R785OC-2GD - graphics card - Radeon HD 7850 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon HD 7850
2 GB GDDR5
Core Clock
975 MHz
Effective Memory Clock
4.8 GHz
Memory Interface
256-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / VGA: 2048 x 1536
Max Monitors Supported
4
DVI-I (dual link) , HDMI , 2 x Mini DisplayPort
API Supported
DirectX 11, OpenGL 4.2
4.3 cm x 24.1 cm x 13.7 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon HD 7850
Core Clock
975 MHz
Process Technology
28 nm
Max Resolution
2560 x 1600
4
API Supported
Avivo HD Technology, Ultra Durable 2, AMD Eyefinity Technology, AMD Eyespeed, GIGABYTE WindForce 2x, AMD CrossFireX Technology
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
4.8 GHz
Bus Width
256-bit
Required Power Supply
500 W
RoHS
4.3 cm
24.1 cm
13.7 cm
