Dunc's Deal Alert
During January 2012 anyone who buys one of these Gigabyte ATI Radeon 6770 775MHz Graphics Card will be able to claim a FREE download voucher for Dirt 3 on PC. Simply order the item and then email duncsdeals@dabs.com with your Sales Order Number to claim, a code will be emailed back within 48 hours
This ultra durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB and reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability.
GIGABYTE Ultra Durable VGA Series
- 1.Powered by AMD Radeon HD 6770 GPU
- 2.Integrated with the first 1GB GDDR5 memory and 128-bit memory interface
- 3.Features Dual-link DVI-I / HDMI / Displayport
- 4.GIGABYTE 100mm Fansink
- 5.Support AMD Eyefinity™ & CrossFireX™ & Avivo™HD
- 6.System power supply requirement: 450W (one 75W 6-pin PCI Express® connector recommended)
Ultra Durable VGA™
GPU Temperature 5%~10% down
Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. GIGABYTE Ultra Durable VGA can lower GPU temperature by 5% to 10%.
Overclocking Capability 10%~30% Up
Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. GIGABYTE Ultra Durable VGA graphic accelerators improve - overclocking capability by 10% to 30%.
Power Switching Loss 10%~30% Down
Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency. GIGABYTE Ultra Durable VGA can lower power switching loss by 10% to 30%.
GIGABYTE custom-designed 10 cm cooler
As opposed to the stereotype, GIGABYTE is able to maximize fan size to 10cm with the latest cooling design. With a 10cm fan, the card is virtually silent that its noise level runs much lower
AMD Eyefinity
Supporting multiple independent display outputs simultaneously, AMD Eyefinity technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience.
Gold plated HDMI
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections. -
GIGABYTE custom-designed cooler
As opposed to the stereotype, GIGABYTE is able to maximize fan size with the cooling design. With a fan, the card is virtually silent that its noise level runs much lower. -
MD Eyefinity
Supporting multiple independent display outputs simultaneously, AMD Eyefinity technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience. -
Cross Fire
CrossFire's "supertiling" GPU sharing speeds rendering by evenly dividing the graphics processing, intelligently alternating the rendering workload to each Radeon GPU for efficient load balancing, and optimized performance. CrossFire boosts image quality along with rendering speed, eliminating the need to crank down screen resolutions to get the high image quality you want. -
Avivo HD
Avivo could provides vibrant high fidelity, flawlessly smooth video playback. Avivo technology easily allows your PCs to become digital home media center by its compelling video pipeline design that comprises the high definition video hardware acceleration. -
RoHS compliant
Give the whole of Earth a promise that the products do not contain any of the restricted substances in concentrations and applications banned by the RoHS directive, and are capable of being worked on at the higher temperatures required for lead free solder.
- Gigabyte GV-R677D5-1GD - graphics card - Radeon HD 6770 - 1 GB
- Graphics card
- Bus Type
- PCI Express 2.1 x16
- Graphics Engine
- AMD Radeon HD 6770
- Memory
- 1 GB GDDR5
- Core Clock
- 775 MHz
- Effective Memory Clock
- 4 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 2560 x 1600
- Max Monitors Supported
- 3
- DVI-I (dual link) , HDMI , DisplayPort
- API Supported
- DirectX 11, OpenGL 4.1
- 4.2 cm x 20.5 cm x 13.4 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 775 MHz
- Max Resolution
- 2560 x 1600
- 3
- API Supported
- Size
- 1 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 4 GHz
- Bus Width
- 128-bit
- Required Power Supply
- 450 W
- Additional Requirements
- 6 pin PCI Express power connector
- RoHS
- 4.2 cm
- 20.5 cm
- 13.4 cm
