Gigabyte Aorus GeForce RTX 5080 MASTER 16GB
Quicklinx: J164WS00 Mfr#: GV-N5080AORUS M-16GD
The Gigabyte GeForce RTX 5080 GAMING OC 16GB is a high-performance graphics card crafted to push the boundaries of gaming and professional workflows. Powered by NVIDIA's Blackwell architecture, this card delivers unparalleled graphical fidelity and computational power, perfect for gaming or ploughing through demanding content creation tasks. Equipped with Gigabyte's WINDFORCE cooling system, the RTX 5080 GAMING OC maintains optimal thermal performance even under heavy loads. The OC Edition of this graphics card comes with factory overclocking, pushing the GPU clock speeds further for an enhanced gaming experience.
NVIDIA DLSS 4 - Supreme Speed. Superior Visuals. Powered by AI
DLSS is a revolutionary suite of neural rendering technologies that uses AI to boost FPS, reduce latency, and improve image quality. ?The latest breakthrough, DLSS 4, brings new Multi Frame Generation and enhanced Ray Reconstruction and Super Resolution, powered by GeForce RTX™ 50 Series GPUs and fifth-generation Tensor Cores. DLSS on GeForce RTX is the best way to play, backed by an NVIDIA AI supercomputer in the cloud constantly improving your PC’s gaming capabilities.
Full Ray Tracing with Neural Rendering - Game-Changing Realism
The NVIDIA Blackwell architecture unlocks the game-changing realism of full ray tracing. Experience cinematic quality visuals at unprecedented speed powered by GeForce RTX 50 Series with fourth-gen RT Cores and breakthrough neural rendering technologies accelerated with fifth-gen Tensor Cores.
NVIDIA Reflex 2 - Compete at Warp Speed
Reflex technologies optimize the graphics pipeline for ultimate responsiveness, providing faster target acquisition, quicker reaction times, and improved aim precision in competitive games. Reflex 2 introduces Frame Warp (coming soon!), which further reduces latency based on the game’s latest mouse input.
RTX AI PCs - NVIDIA Powers the World’s AI. And Yours
Upgrade to advanced AI with NVIDIA GeForce RTX™ GPUs and accelerate your gaming, creating, productivity, and development. Thanks to built-in AI processors, you get world-leading AI technology powering your Windows PC.
NVIDIA Studio - Your Creative AI-dvantage
NVIDIA Studio is your creative advantage. GeForce RTX 50 Series GPUs unlock transformative performance in video editing, 3D rendering, and graphic design. Experience RTX accelerations in top creative apps, world-class NVIDIA Studio drivers engineered and continually updated to provide maximum stability, and a suite of exclusive tools that harness the power of RTX for AI-assisted creative workflows.
  • Robust memory capacity
    The graphics card boasts 16 GB of GDDR7 SDRAM, ensuring ample memory for handling high-resolution textures and complex graphical tasks seamlessly.
  • Advanced cooling technology
    Engineered with GIGABYTE WINDFORCE cooling design, this card features a triple fan setup to efficiently dissipate heat and maintain optimal performance during extended use.
  • Enhanced gaming visuals
    NVIDIA G-Sync compatibility eliminates screen tearing and stuttering, delivering a smoother and more immersive gaming experience for competitive play.
  • High external resolution support
    With a maximum resolution of 7680 x 4320, this graphics card is ideal for ultra-high-definition gaming and professional content creation on multiple screens.
  • Versatile connectivity options
    This card includes multiple output interfaces, including HDMI and DisplayPort connections, allowing for flexible connectivity to various display setups.
AORUS GeForce RTX 5080 MASTER 16G - OC Edition - graphics card - GeForce RTX 5080 - 16 GB
Graphics card
Bus Type
PCI Express 5.0
Graphics Engine
NVIDIA GeForce RTX 5080
16 GB GDDR7
Memory Speed
30 Gbps
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
3 x DisplayPort , HDMI
API Supported
OpenGL 4.6, DirectX 12
7.5 cm x 36 cm x 15 cm
Package Type
Box
3-year warranty
Graphics card
Bus Type
PCI Express 5.0
Graphics Engine
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
GIGABYTE WINDFORCE cooling design, Dual Bios, RGB Lighting, NVIDIA DLSS 4, NVIDIA Reflex 2, Nvidia Studio, Triple Fan Design, Nvidia Broadcast, 9th Gen NVIDIA Encoder, NVIDIA Avatar Cloud Engine (ACE), NVIDIA G-Sync ready, 5th gen Tensor Cores, 4th gen Ray Tracing Cores, Ray Tracing, Hawk Fan design, Passive Cooling Solution, screen cooling plus, GIGABYTE RGB Halo, LCD Edge View, metal backplate, PCB design, Ultra Durable VGA, 2oz copper PCB, DrMOS, dust resistant, moisture resistant, corrosion resistant, NVIDIA Blackwell GPU architecture
Size
16 GB
GDDR7 SDRAM
Memory Speed
30 Gbps
Bus Width
256-bit
Required Power Supply
850 W
Additional Requirements
16 pin PCI Express power connector
Graphics card holder, 3 x 8 pin to 12VHPWR cable, AORUS identity stickers, screen cooling plus RGB fan
Software Included
Gigabyte Control Center
DisplayPort 2.1a
7.5 cm
36 cm
15 cm
Package Details
Box
Limited warranty - 3 years , Limited warranty - extended warranty with product registration - 4 Years
