Gigabyte AORUS GeForce RTX 4090 MASTER 24GB Graphics Card
Quicklinx: HX0GWS00 Mfr#: GV-N4090AORUS M-24GD
Graphics Processor Manufacturer: NVIDIA
Graphics Processor: NVIDIA GeForce RTX 4090
Interface: PCI Express 4.0
£1,622.55 ex VAT
£1,947.06 inc VAT
The NVIDIA GeForce RTX 4090 is the ultimate GeForce GPU. It brings an enormous leap in performance, efficiency, and AI-powered graphics. Experience ultra-high performance gaming, incredibly detailed virtual worlds, unprecedented productivity, and new ways to create. It’s powered by the NVIDIA Ada Lovelace architecture and comes with 24 GB of G6X memory to deliver the ultimate experience for gamers and creators.
  • WINDFORCE cooling system
    The WINDFORCE cooling system features three 110 mm designed bionic shark fans, alternate spinning, 13 composite copper heat pipes, a large vapor chamber directly touches the GPU, 3D active fans and Screen cooling, which together provide high efficiency heat dissipation.
  • Cooling, upscaled
    The sharks' dermal denticles surrounding their body grant them significant advantages in fluid dynamics.
  • Directly. so fast
    The large vapor chamber directly contacts the GPU, coupled with the composite heat pipes, which quickly transfers the heat of the GPU and VRAM to the heatsink.
  • Channeled airflow
    The angular and unequal fins height can channel the airflow through the fins and enlarge the contact surface.
  • Make room for the airflow
    To create more space for airflow to pass through, the heatsink extends over the PCB and therefore increase the ventilation. This Screen Cooling design provides better heat dissipation.
  • LCD Edge View
    The LCD monitor displays not only graphics card information, but also various favorite texts, pictures, and GIFs.
  • RGB Fusion
    The legendary three-ring lighting provides excellent visual enjoyment.
  • Dual BIOS
    The factory default setting is OC mode, which provides users with the best performance. However, switching to silent mode will enjoy a quieter experience.
  • Protection metal back plate
    The metal back plate not only provides an aesthetical shape, but also enhances the structure of the graphics card to provide complete protection.
  • Anti-sag bracket
    The anti-sag bracket is tailored to each graphics card. It provides the optimized reinforcement and better overall visual appearance.
  • Power indicators
    When experiencing any power supply abnormality, the indicator will alert gamers by flashing light.
  • PCB coating
    Dust resistant - shields from dust, insects, dropped screws, drill shavings, and abrasion. Moisture resistant - prevents unwanted conduction paths and board damage. Corrosion resistant - protects from salt spray, humidity, and corrosion.
  • Extreme overclocking
    The graphics card features excellent power phase design to allow the MOSFETs to operate at lower temperatures and provide a more stable voltage output. Load balancing of each MOSFET can effectively improve the overclocking performance and extend the life of the card.
  • Ultra durable
    Ultra durable certified highest-grade metal chokes, lower ESR solid capacitors, 2 oz copper PCB, and lower RDS (on) MOSFETs, plus over-temperature design to deliver superior performance and longer system life.
  • Friendly PCB design
    Fully automated production process ensures top quality of the circuit boards and eliminates sharp protrusions of the solder connectors seen on the conventional PCB surface. This friendly design prevents your hands from getting cut or inadvertently damaging components when making your build.
Gigabyte AORUS GeForce RTX 4090 MASTER 24G - graphics card - NVIDIA GeForce RTX 4090 - 24 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
NVIDIA GeForce RTX 4090 - up to
24 GB GDDR6X
Memory Speed
21 Gbps
Core Clock
2550 MHz
CUDA Cores
16384
Memory Interface
384-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
3 x DisplayPort , HDMI
API Supported
DirectX 12 Ultimate, OpenGL 4.6
7.51 cm x 35.85 cm x 16.28 cm
4 years warranty
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Core Clock
2550 MHz
CUDA Cores
16384
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
3rd gen Tensor Cores, 4th gen Tensor Cores, Dual Bios, GIGABYTE WINDFORCE cooling design, LCD Edge View, metal backplate, NVIDIA Ada Lovelace GPU technology, RGB fusion, Nvidia Broadcast, NVIDIA DLSS 3, NVIDIA Reflex, Nvidia Studio, 3D Active Fan, Dual ball Bearing Fan, Gigabyte Alternate Spinning, Vapour Chamber Combined Heat-pipe Design
Size
24 GB
GDDR6X SDRAM
Memory Speed
21 Gbps
Bus Width
384-bit
Required Power Supply
1000 W
Additional Requirements
16 pin PCI Express power connector
AORUS metal sticker
DisplayPort 1.4
7.51 cm
35.85 cm
16.28 cm
Limited warranty - 4 Years
Brand: Gigabyte
Price Range Ex VAT: £1500+
