The NVIDIA GeForce RTX 4090 is the ultimate GeForce GPU. It brings an enormous leap in performance, efficiency, and AI-powered graphics. Experience ultra-high performance gaming, incredibly detailed virtual worlds, unprecedented productivity, and new ways to create. It’s powered by the NVIDIA Ada Lovelace architecture and comes with 24 GB of G6X memory to deliver the ultimate experience for gamers and creators.
WINDFORCE cooling system
The WINDFORCE cooling system features three 110 mm designed bionic shark fans, alternate spinning, 13 composite copper heat pipes, a large vapor chamber directly touches the GPU, 3D active fans and Screen cooling, which together provide high efficiency heat dissipation. -
Cooling, upscaled
The sharks' dermal denticles surrounding their body grant them significant advantages in fluid dynamics. -
Directly. so fast
The large vapor chamber directly contacts the GPU, coupled with the composite heat pipes, which quickly transfers the heat of the GPU and VRAM to the heatsink. -
Channeled airflow
The angular and unequal fins height can channel the airflow through the fins and enlarge the contact surface. -
Make room for the airflow
To create more space for airflow to pass through, the heatsink extends over the PCB and therefore increase the ventilation. This Screen Cooling design provides better heat dissipation. -
LCD Edge View
The LCD monitor displays not only graphics card information, but also various favorite texts, pictures, and GIFs. -
RGB Fusion
The legendary three-ring lighting provides excellent visual enjoyment. -
Dual BIOS
The factory default setting is OC mode, which provides users with the best performance. However, switching to silent mode will enjoy a quieter experience. -
Protection metal back plate
The metal back plate not only provides an aesthetical shape, but also enhances the structure of the graphics card to provide complete protection. -
Anti-sag bracket
The anti-sag bracket is tailored to each graphics card. It provides the optimized reinforcement and better overall visual appearance. -
Power indicators
When experiencing any power supply abnormality, the indicator will alert gamers by flashing light. -
PCB coating
Dust resistant - shields from dust, insects, dropped screws, drill shavings, and abrasion. Moisture resistant - prevents unwanted conduction paths and board damage. Corrosion resistant - protects from salt spray, humidity, and corrosion. -
Extreme overclocking
The graphics card features excellent power phase design to allow the MOSFETs to operate at lower temperatures and provide a more stable voltage output. Load balancing of each MOSFET can effectively improve the overclocking performance and extend the life of the card. -
Ultra durable
Ultra durable certified highest-grade metal chokes, lower ESR solid capacitors, 2 oz copper PCB, and lower RDS (on) MOSFETs, plus over-temperature design to deliver superior performance and longer system life. -
Friendly PCB design
Fully automated production process ensures top quality of the circuit boards and eliminates sharp protrusions of the solder connectors seen on the conventional PCB surface. This friendly design prevents your hands from getting cut or inadvertently damaging components when making your build.
- Gigabyte AORUS GeForce RTX 4090 MASTER 24G - graphics card - NVIDIA GeForce RTX 4090 - 24 GB
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- Memory
- 24 GB GDDR6X
- Memory Speed
- 21 Gbps
- Core Clock
- 2550 MHz
- CUDA Cores
- 16384
- Memory Interface
- 384-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- 3 x DisplayPort , HDMI
- API Supported
- DirectX 12 Ultimate, OpenGL 4.6
- 7.51 cm x 35.85 cm x 16.28 cm
- 4 years warranty
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- Core Clock
- 2550 MHz
- CUDA Cores
- 16384
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- 3rd gen Tensor Cores, 4th gen Tensor Cores, Dual Bios, GIGABYTE WINDFORCE cooling design, LCD Edge View, metal backplate, NVIDIA Ada Lovelace GPU technology, RGB fusion, Nvidia Broadcast, NVIDIA DLSS 3, NVIDIA Reflex, Nvidia Studio, 3D Active Fan, Dual ball Bearing Fan, Gigabyte Alternate Spinning, Vapour Chamber Combined Heat-pipe Design
- Size
- 24 GB
- Technology
- GDDR6X SDRAM
- Memory Speed
- 21 Gbps
- Bus Width
- 384-bit
- Required Power Supply
- 1000 W
- Additional Requirements
- 16 pin PCI Express power connector
- Included Accessories
- AORUS metal sticker
- DisplayPort 1.4
- 7.51 cm
- 35.85 cm
- 16.28 cm
- Limited warranty - 4 Years
