Gigabyte AORUS GeForce RTX 4070 SUPER MASTER 12G Graphics Card
Quicklinx: HVHJWS00 Mfr#: GV-N407SAORUS M-12GD
The GIGABYTE AORUS GeForce RTX 4070 SUPER MASTER 12G is designed for gamers and creative professionals who demand high performance and reliability. With 12 GB of GDDR6X SDRAM and a 192-bit bus width, it delivers exceptional speed and bandwidth for smooth, detailed visuals in games and applications. The card features the GIGABYTE WINDFORCE cooling system, including AORUS Bionic fan technology and Vapor chamber direct touch, ensuring your system stays cool. Supporting DirectX 12 Ultimate and OpenGL 4.6, it's ready for the next generation of gaming. Additionally, NVIDIA's technologies like DLSS 3 and Reflex enhance your gaming experience with sharper images and lower latency. The card's durability is bolstered by a metal backplate and PCB coating, protecting against dust, moisture, and corrosion. With support for up to 4 monitors and a maximum resolution of 7680 x 4320, it's perfect for immersive gaming setups or extensive creative projects. Customize your gaming environment with RGB fusion technology, offering a spectrum of colors and lighting effects to match your style.
  • Advanced cooling
    The GIGABYTE AORUS GeForce RTX 4070 SUPER MASTER 12G features the GIGABYTE WINDFORCE cooling design, incorporating AORUS Bionic fan technology, Vapor chamber direct touch technology, and composite heatpipes to ensure your gaming sessions remain cool.
  • Exceptional performance
    Equipped with NVIDIA GeForce RTX 4070 SUPER graphics processor and 12 GB of GDDR6X SDRAM, this video card delivers a memory speed of 21 Gbps and a 192-bit bus width, making it suitable for high-resolution gaming and creative work.
  • Immersive gaming
    Supporting DirectX 12 Ultimate and OpenGL 4.6, along with NVIDIA DLSS 3, NVIDIA Reflex, and Nvidia Broadcast technologies, the card offers a seamless and immersive gaming experience with reduced latency and improved image quality.
  • Enhanced durability
    The card is built to last, featuring a metal backplate, PCB dust/moisture/corrosion coating, and an anti-sag bracket, ensuring both stability and longevity for your gaming rig.
  • Vivid visuals
    Achieve stunning visuals with support for up to 4 monitors and a maximum external resolution of 7680 x 4320. The inclusion of RGB fusion technology allows for customizable lighting effects, enhancing the aesthetic appeal of your gaming setup.
AORUS GeForce RTX 4070 SUPER MASTER 12G - graphics card - GeForce RTX 4070 Super - 12 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
12 GB GDDR6X
Memory Speed
21 Gbps
Core Clock
2655 MHz
CUDA Cores
7168
Memory Interface
192-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
3 x DisplayPort (version 1.4a) , HDMI
API Supported
DirectX 12 Ultimate, OpenGL 4.6
15.3 cm x 34.2 cm x 7.06 cm
3-year warranty
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Core Clock
2655 MHz
CUDA Cores
7168
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
3rd gen Tensor Cores, 4th gen Tensor Cores, Dual Bios, GIGABYTE WINDFORCE cooling design, metal backplate, NVIDIA Ada Lovelace GPU technology, NVIDIA DLSS 3, RGB fusion, 3D Active Fan, AORUS Bionic fan technology, composite heatpipes, Gigabyte Alternate Spinning, NVIDIA Reflex, screen cooling, Vapour chamber direct touch technology, factory overclocked, LED indicator, PCB dust/moisture/corrosion coating, Nvidia Broadcast, Nvidia Studio
Size
12 GB
GDDR6X SDRAM
Memory Speed
21 Gbps
Bus Width
192-bit
Required Power Supply
700 W
Additional Requirements
16 pin PCI Express power connector
Anti-sag bracket, 16-pin to 2x 8-pin power adapter, AORUS metal sticker
Software Included
Gigabyte Control Center
DisplayPort 1.4a
15.3 cm
34.2 cm
7.06 cm
Limited warranty - 3 years , Limited warranty - extended warranty with product registration - 4 Years
