Gigabyte AORUS GeForce RTX 4060 Ti ELITE 8GB Graphics Card
Quicklinx: HVHKWS00 Mfr#: GV-N406TAORUS E-8GD
Ahead of its time, ahead of the game is the Gigabyte AORUS GeForce RTX 4060 Ti ELITE 8G Graphics Cards. Powered by NVIDIA's RTX architecture, the Gigabyte AORUS GeForce RTX 4060 Ti ELITE 8G Graphics Cards brings stunning visuals, amazingly fast frame rates, and AI acceleration to games and creative applications with its enhanced RT Cores and Tensor Cores, along with a staggering 8 GB of GDDR6 memory.
  • RGB Fusion
    The legendary three-ring lighting provides excellent visual enjoyment. You can choose any lighting effect or synchronize with other devices in Gigabyte control center.
  • Dual BIOS
    The factory default setting is OC mode, which provides users with the best performance. However, switching to silent mode will enjoy a quieter experience.
  • Protection metal back plate
    The metal back plate not only provides an aesthetical shape, but also enhances the structure of the graphics card to provide complete protection.
  • Power indicator
    When experiencing any power supply abnormality, the indicator will alert gamers by flashing light.
  • PCB Coating
    Dust resistant - shields from dust, insects, dropped screws, drill shavings, and abrasion. Moisture resistant - prevents unwanted conduction paths and board damage. Corrosion resistant - protects from salt spray, humidity, and corrosion.
  • Extreme overclocking
    The graphics card features excellent power phase design to allow the MOSFETS to operate at lower temperatures and provide a more stable voltage output. Load balancing of each MOSFET can effectively improve the overclocking performance and extend the life of the card.
  • Ultra Durable
    Ultra Durable certified highest-grade metal chokes, lower ESR solid capacitors, 2oz copper PCB, and lower RDS (on) MOSFETs, plus over-temperature design to deliver superior performance and longer system life.
  • Friendly PCB design
    Fully automated production process ensures top quality of the circuit boards and eliminates sharp protrusions of the solder connectors seen on the conventional PCB surface. This friendly design prevents your hands from getting cut or inadvertently damaging components when making your build.
AORUS GeForce RTX 4060 Ti ELITE 8G - graphics card - GeForce RTX 4060 Ti - 8 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
NVIDIA GeForce RTX 4060 Ti - up to
8 GB GDDR6
Memory Speed
18 Gbps
Core Clock
2655 MHz
CUDA Cores
4352
Memory Interface
128-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
2 x DisplayPort , 2 x HDMI
API Supported
DirectX 12 Ultimate, OpenGL 4.6
5.6 cm x 30.1 cm x 12.8 cm
4 years warranty
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Core Clock
2655 MHz
CUDA Cores
4352
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
3rd gen Ray Tracing Cores, 4th gen Tensor Cores, Dual Bios, GIGABYTE WINDFORCE cooling design, metal backplate, NVIDIA Ada Lovelace GPU technology, 3D Active Fan, Gigabyte Alternate Spinning, Nvidia Broadcast, NVIDIA DLSS 3, NVIDIA Reflex, Nvidia Studio, Heat Pipe Direct Touch technology, screen cooling, RGB fusion
Size
8 GB
GDDR6 SDRAM
Memory Speed
18 Gbps
Bus Width
128-bit
Required Power Supply
500 W
Additional Requirements
8 pin PCI Express power connector
Software Included
Gigabyte Control Center
DisplayPort 1.4a
5.6 cm
30.1 cm
12.8 cm
Limited warranty - 4 Years
