Gigabyte AORUS GeForce RTX™ 5090 MASTER 32G
Quicklinx: J1DNWS00 Mfr#: GV-N5090AORUS M-32GD
  • Powered by the NVIDIA Blackwell architecture and DLSS 4
  • Powered by GeForce RTX™ 5090
  • Integrated with 32GB GDDR7 512bit memory interface
  • WINDFORCE cooling system
  • Hawk fan
  • Composite metal grease for GPU
  • Server-grade thermal conductive gel
  • Superconducting heat pipes
  • LCD edge view
  • RGB Halo
  • Dual BIOS (Performance / Silent)
  • Reinforced structure
  • Versatile VGA holder
  • 4 years warranty (Online registration required)
The Gigabyte AORUS GeForce RTX 5090 MASTER 32GB is a high-performance graphics card crafted to push the boundaries of gaming and professional workflows. Powered by NVIDIA's Blackwell architecture, this card delivers unparalleled graphical fidelity and computational power, perfect for gaming or ploughing through demanding content creation tasks. Equipped with Gigabyte's WINDFORCE cooling system, the RTX 5090 GAMING OC maintains optimal thermal performance even under heavy loads. The OC Edition of this graphics card comes with factory overclocking, pushing the GPU clock speeds further for an enhanced gaming experience.
NVIDIA DLSS 4 - Supreme Speed. Superior Visuals. Powered by AI
DLSS is a revolutionary suite of neural rendering technologies that uses AI to boost FPS, reduce latency, and improve image quality. ?The latest breakthrough, DLSS 4, brings new Multi Frame Generation and enhanced Ray Reconstruction and Super Resolution, powered by GeForce RTX™ 50 Series GPUs and fifth-generation Tensor Cores. DLSS on GeForce RTX is the best way to play, backed by an NVIDIA AI supercomputer in the cloud constantly improving your PC’s gaming capabilities.
Full Ray Tracing with Neural Rendering - Game-Changing Realism
The NVIDIA Blackwell architecture unlocks the game-changing realism of full ray tracing. Experience cinematic quality visuals at unprecedented speed powered by GeForce RTX 50 Series with fourth-gen RT Cores and breakthrough neural rendering technologies accelerated with fifth-gen Tensor Cores.
NVIDIA Reflex 2 - Compete at Warp Speed
Reflex technologies optimize the graphics pipeline for ultimate responsiveness, providing faster target acquisition, quicker reaction times, and improved aim precision in competitive games. Reflex 2 introduces Frame Warp (coming soon!), which further reduces latency based on the game’s latest mouse input.
RTX AI PCs - NVIDIA Powers the World’s AI. And Yours
Upgrade to advanced AI with NVIDIA GeForce RTX™ GPUs and accelerate your gaming, creating, productivity, and development. Thanks to built-in AI processors, you get world-leading AI technology powering your Windows PC.
NVIDIA Studio - Your Creative AI-dvantage
NVIDIA Studio is your creative advantage. GeForce RTX 50 Series GPUs unlock transformative performance in video editing, 3D rendering, and graphic design. Experience RTX accelerations in top creative apps, world-class NVIDIA Studio drivers engineered and continually updated to provide maximum stability, and a suite of exclusive tools that harness the power of RTX for AI-assisted creative workflows.
  • Powerful performance
    The NVIDIA GeForce RTX 5090 GPU delivers gaming performance with 21760 CUDA cores and clock speeds reaching 2655 MHz, ensuring that even the most demanding games run smoothly.
  • Advanced cooling technology
    The GIGABYTE WINDFORCE cooling design incorporates dual ball bearing fans and screen cooling plus, providing efficient heat dissipation to maintain stable performance during intense gaming sessions.
  • Robust build quality
    A metal reinforced backplate and 2 oz copper PCB enhance durability, while dust, moisture, and corrosion resistance features ensure the longevity of the graphics card.
  • Immersive visual experience
    The combination of RGB lighting, NVIDIA G-Sync readiness, and support for multiple display outputs enhances visual experience, providing gamers with smooth and immersive graphics.
  • Comprehensive features
    With capabilities like NVIDIA Multi Frame Generation, the 5th gen Tensor Cores, and 3D Active Fan functionality, this graphics card is designed to meet a wide range of gaming and professional needs.
AORUS GeForce RTX 5090 MASTER 32G - OC Edition - graphics card - GeForce RTX 5090 - 32 GB
Graphics card
Bus Type
PCI Express 5.0
Graphics Engine
32 GB GDDR7
Memory Speed
28 Gbps
Core Clock
2655 MHz
CUDA Cores
21760
Memory Interface
512-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
3 x DisplayPort ¦ HDMI
API Supported
DirectX 12, OpenGL 4.6
7.5 cm x 36 cm x 15 cm
4-year warranty with product registration
Graphics card
Bus Type
PCI Express 5.0
Graphics Engine
Core Clock
2655 MHz
CUDA Cores
21760
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
NVIDIA Blackwell GPU architecture, NVIDIA DLSS 4, NVIDIA G-Sync ready, NVIDIA Reflex 2, NVIDIA Multi Frame Generation, NVIDIA Frame Warp, NVIDIA Avatar Cloud Engine (ACE), 5th gen Tensor Cores, 4th gen Ray Tracing Cores, GIGABYTE WINDFORCE cooling design, Hawk Fan design, server-grade thermal conductive gel, LCD Edge View, GIGABYTE RGB Halo, Dual Bios, screen cooling plus, Gigabyte Alternate Spinning, Dual ball Bearing Fans, 3D Active Fan, RGB Lighting, metal reinforced backplate, LED indicator, Ultra Durable VGA, dust resistant, moisture resistant, corrosion resistant, 2oz copper PCB
Size
32 GB
GDDR7 SDRAM
Memory Speed
28 Gbps
Bus Width
512-bit
Required Power Supply
1000 W
Additional Requirements
16 pin PCI Express power connector
16-pin to 4x 8-pin cable adapter, AORUS identity stickers, AORUS metal sticker, VGA Holder
Software Included
GeForce Game Ready Drivers, NVIDIA Studio drivers, Gigabyte Control Center
DisplayPort 2.1b
7.5 cm
36 cm
15 cm
Limited warranty - 3 years , Limited warranty - 4 years with product registration (within 30 days of purchase)
