Gigabyte AMD Radeon RX460 OC 2GB GDDR5 WINDFORCE2 PCIe3.0
Quicklinx: C9GYWS00 Mfr#: GV-RX460WF2OC-2GD
Radeon™ RX460 WINDFORCE OC 2G
Powered by Radeon RX460
Integrated with 2GB GDDR5 128bit memory
WINDFORCE 2X with Blade Fan Design
Support Full UHD HEVC Encode and Decode
Core Clock
1212 MHz
  • Improved blade fan design
    The airflow is spilled by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow.
  • 3D active fan
    The semi-passive fans will remain off, when the GPU is under a set loading or temperature for low power gaming. It allows gamers to enjoy gameplay in complete silence, when the system is running light or idle.
  • Ultra-durable graphics components
    Engineered with the high-grade chokes and capacitors, the graphic card delivers outstanding performance and durable system lifespan.
  • Built for overclocking with 4+1 power phases
    The 4+1 power phases on the card make the MOSFET working at a lower temperature and provide more stable voltage output.
Gigabyte GV-RX460WF2OC-2GD - OC Edition - graphics card - Radeon RX 460 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x8
Graphics Engine
AMD Radeon RX 460 - up to
2 GB GDDR5
Core Clock
1212 MHz
Effective Memory Clock
7 GHz
Memory Interface
128-bit
Max Resolution
7680 x 4320
Max Monitors Supported
3
Interfaces Details
HDMI , DisplayPort , DVI-D (dual link)
API Supported
DirectX 12, OpenGL 4.5
3.7 cm x 19.1 cm x 11.1 cm
Graphics card
Bus Type
PCI Express 3.0 x8
Graphics Engine
AMD Radeon RX 460
Core Clock
1212 MHz
Process Technology
14 nm
Max Resolution
7680 x 4320 at 60 Hz
3
Interfaces Details
API Supported
Ultra Durable VGA, AMD Eyefinity Technology, GIGABYTE WindForce 2x, Dual Fan Design, AMD CrossFireX Technology, 4+1 Phase Power Design
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
7 GHz
Bus Width
128-bit
Required Power Supply
350 W
Software Included
XTREME Engine Utility
3.7 cm
19.1 cm
11.1 cm
