Gigabyte AMD Radeon RX 550 GAMING OC 2GB PCIe3.0 Graphics Card
Quicklinx: CVNVWS00 Mfr#: GV-RX550GAMING OC-2GD
The cooling system features two unique blade fans and 3D active fan functionality, delivering an effective heat dissipation capacity for higher performance at lower temperatures.
  • Unique blade fan design
    The airflow is split by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow.
  • 3D active fan
    The semi-passive fans will remain off when the GPU is under a set loading or temperature for lower power gaming. It allows gamers to enjoy gameplay in complete silence when the system is running light or idle.
  • Durable components
    Engineered with high-quality chokes and capacitors, this graphic card delivers outstanding performance and durable system lifespan.
  • Smooth and crisp visual
    Equipped with extensive connectivity ports, the card can deliver beautiful and smooth video playback.
Gigabyte Radeon RX 550 Gaming OC 2G - graphics card - Radeon RX 550 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon RX 550 - up to
2 GB GDDR5
Core Clock
1219 MHz
Effective Memory Clock
7 GHz
Memory Interface
128-bit
Max Resolution
7680 x 4320
Max Resolution Details
DisplayPort: 7680 x 4320 at 60 Hz/ HDMI: 4096 x 2160 at 60 Hz
Max Monitors Supported
3
Interfaces Details
DVI-D (dual link) , HDMI , DisplayPort
API Supported
DirectX 12, OpenGL 4.5
3.7 cm x 19.1 cm x 11.1 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon RX 550
Core Clock
1219 MHz
Process Technology
14 nm
Max Resolution
7680 x 4320
3
Interfaces Details
API Supported
Ultra Durable 2, AMD Eyefinity Technology, GIGABYTE Super Overclock, GIGABYTE WindForce 2x, Dual Fan Design, solid state capacitors, FreeSync Technology, AMD XConnect Technology, AORUS Graphics Engine
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
7 GHz
Bus Width
128-bit
Required Power Supply
400 W
DisplayPort 1.4
3.7 cm
19.1 cm
11.1 cm
