Gigabyte AMD Radeon R9 290 1040MHz 4GB PCI-E 3.0 HDMI Windforce 3X OC w/ BF4
Quicklinx: 96V4WS00 Mfr#: GV-R929OC-4GD-GA
  • AMD Radeon R9 290
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
Keeping the same 450W Cooling capacity using only 2 slots, the New WINDFORCE 3X 450W cooling system is equipped with two 8mm and four 6mm cooper heat-pipes , inclined fans, and GIGABYTE "Triangle Cool" technology. This not only provides an effective heat dissipation capacity but also enables higher performance due to a lower temperature.
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up MONITORING, GPU CLOCK, MEMORY CLOCK,FAN, OSD, ONLINE SUPPORT and update driver, BIOS directly.
Supporting multiple independent display outputs simultaneously, AMD Eyefinity technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience.
  • Limited edition with Battlefield 4
  • WINDFORCE 3X 450W cooling system
  • Powered by AMD Radeon™ R9 290 GPU
  • Integrated with 4GB GDDR5 memory, 512-bit memory interface
  • Features DVI-D*2 / HDMI / DisplayPort
  • Core Clock: 1040 MHz
  • System power supply requirement: 600W
  • WINDFORCE 3X 2 SLOT 450W cooling system
    Keeping the same 450W cooling capacity using only 2 slots, the WINDFORCE 3X 450W cooling system is equipped with two 8 mm and four 6 mm cooper heat-pipes, inclined fans, and GIGABYTE "Triangle Cool" technology. This not only provides an effective heat dissipation capacity but also enables higher performance due to a lower temperature.
  • OC GURU ll
    Instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up monitoring, GPU clock, memory clock, fan, OSD, online support and update driver, BIOS directly.
  • AMD Eyefinity
  • Smart fan control
    With built-in a hardware switch, you can easily change the fan profile to silent mode or performance mode.
  • Silent mode
    The fan always run low speeds to provide a quiet working environment unless the GPU temperature reach to the target.
  • Performance mode
    The fan speed will be dynamically adjusted based on the GPU temperature variation, which can keep the GPU temperature lower to get a better performance.
Gigabyte GV-R929OC-4GD-GA - Battlefield 4 Limited Edition - graphics card - Radeon R9 290 - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R9 290
4 GB GDDR5
Core Clock
1040 MHz
Effective Memory Clock
5 GHz
Memory Interface
512-bit
Max Resolution
4096 x 2160
Max Resolution Details
DisplayPort: 4096 x 2160 / HDMI: 4096 x 2160
Max Monitors Supported
4
2 x DVI-D (dual link) , HDMI , DisplayPort
API Supported
OpenGL 4.3, DirectX 11.2
4.1 cm x 29.4 cm x 14.1 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R9 290
Core Clock
1040 MHz
Process Technology
28 nm
Max Resolution
4096 x 2160
4
API Supported
Dual Slot Fan Cooler, AMD Eyefinity Technology, AMD HD3D Technology, AMD CrossFireX Technology, GIGABYTE WindForce 3x, AMD App Acceleration, Triangle Cool Technology, Graphics Core Next (GCN), OC Guru II
Size
4 GB
GDDR5 SDRAM
Effective Clock Speed
5 GHz
Bus Width
512-bit
Required Power Supply
600 W
Additional Requirements
6-pin + 8-pin power connectors
Software Included
AMD Catalyst Control Center, OC Guru ll, Battlefield 4 coupon
4.1 cm
29.4 cm
14.1 cm
