Gigabyte AMD Radeon R7 360 OC 2GB GDDR5 PCI-E Graphics Card
Quicklinx: BF26WS00 Mfr#: GV-R736OC-2GD
90mm LARGE FAN design brings ultimate cooling, efficiency, and quietness.
OC Edition with Core Clock of 1200MHz (Std: 1050MHz)
2GB GDDR5 memory and 128-bit memory interface
Ultra Durable 2 technology delivers lower temperature and longer system lifespan
OC GURU II -- Brand-new intuitive interface helps you easily modify important settings and directly update driver and BIOS.
Chipset - Radeon R7 360
Core Clock - 1200 MHz (standard: 1050 MHz)
Process Technology 28 nm
Memory Clock 6500 MHz
Memory Size 2GB
Memory Bus 128-bit
Memory Type GDDR5
Card Bus PCI-E 3.0
DirectX 12
OpenGL 4.4
PCB Form ATX
Digital max resolution 4096 X 2160
Analog max resolution 2048 x 1536
Multi-view 4
I/O - Dual-link DVI-I1/DVI-D1/HDMI1/Display Port1
Card size H=42 mm, L=159 mm, W=127 mm
Power requirement 500W (with one 6-pin external power connector)
  • GIGABYTE custom-designed 90 mm cooler
    GIGABYTE custom-designed 90 mm cooler, with air flow optimized cover and aluminum base. The cooler can dissipate heat effectively from the GPU while keeping the fan at lower speed and noise.
  • Unique blade fan design
    The airflow is spit through the triangle design at the fan edge, and is guided smoothly through the fan by special 3D stripe curve design. At the same time, it effectively enhanced the cooling capacity while reducing air turbulence.
Gigabyte GV-R736OC-2GD (rev. 1.0) - OC Edition - graphics card - Radeon R7 360 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R7 360
2 GB GDDR5
Core Clock
1200 MHz
Effective Memory Clock
6.5 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
Interfaces Details
DVI-D (dual link) , HDMI , DisplayPort , DVI-I (dual link)
API Supported
OpenGL 4.4, DirectX 12
4.2 cm x 15.9 cm x 12.7 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R7 360
Core Clock
1200 MHz
Process Technology
28 nm
Max Resolution
4096 x 2160
4
Interfaces Details
API Supported
Ultra Durable 2, GIGABYTE WINDFORCE cooling design, solid state capacitors, OC Guru II, GIGABYTE custom-designed 90 mm cooler
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6.5 GHz
Bus Width
128-bit
Required Power Supply
500 W
Additional Requirements
Two 6-pin power connectors
Software Included
OC Guru ll
4.2 cm
15.9 cm
12.7 cm
