- Model name GV-R779OC-2GD
- GPU Radeon HD 7790
- Core Clock (MHz) 1075 MHz (std1000MHz)
- Stream Processor 896
- Mem Clock (MHz) 6000MHz
- Mem Size 2GB
- Mem Bus (bit) 128bit
- Mem Type GDDR5 64Mx32
- Memory (pcs) 8
- I/O Dual link DVI-I DVI-D HDMI x1 DisplayPort*1
- DirectX OpenGL DirectX 11.1 OpenGL 4.2
- Card Interface PCI Express 3.0
- Board Form ATX 2 slot
- Fan/Heat Sink WINDFORCE 2X with "Trangle Cool"
Ultra Durable 2
Gigabyte Ultra Durable 2 edition graphics card now features a sophisticated layout topology. This state-of-the-art power design from Gigabyte delivers the ideal integration of thermal, electric characteristics, digital signals, power circuitry and optimum placement of components for enhanced graphics performance. -
"Triangle Cool" technology
"Triangle Cool" technology combines fin with clip module in a special triangle shape. With the original anti-turbulence structure plus the triangle cooling design, it enhances the efficiency of heat dissipation dramatically by minimizing the flow of turbulence between fans. Therefore, the "Triangle Cool" technology provides a more efficient air flow for the cooling system. -
AMD Eyefinity
Supporting multiple independent display outputs simultaneously, AMD Eyefinity technology delivers graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience. -
CrossFireX
Upgrade to even greater 3D performance quickly and easily thanks to Plug-and-Play ATI CrossFireX multi-GPU technology -
Avivo HD
Avivo could provides vibrant high fidelity, flawlessly smooth video playback. Avivo technology easily allows your PCs to become digital home media center by its compelling video pipeline design that comprises the high definition video hardware acceleration, including H. 264 and WMV9.
- Gigabyte GV-R779OC-2GD - graphics card - Radeon HD 7790 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD Radeon HD 7790
- Memory
- 2 GB GDDR5
- Core Clock
- 1075 MHz
- Effective Memory Clock
- 6 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 2560 x 1600
- Max Resolution Details
- DVI: 2560 x 1600 / VGA: 2048 x 1536
- Max Monitors Supported
- 3
- DVI-I (dual link) , DVI-D , HDMI , DisplayPort
- API Supported
- DirectX 11, OpenGL 4.2
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1075 MHz
- Process Technology
- 28 nm
- Max Resolution
- 2560 x 1600
- 3
- API Supported
- Avivo HD Technology, Ultra Durable 2, AMD Eyefinity Technology, AMD Eyespeed, AMD CrossFireX Technology, Triangle Cool Technology
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6 GHz
- Bus Width
- 128-bit
- Required Power Supply
- 450 W
- RoHS
