Gigabyte Aire M73 Eco-Friendly Wireless Mouse
Quicklinx: 9R1BWS00 Mfr#: AIRE M73
Save your power anytime! The thoughtful design of on-the-top power key makes it more intuitive to power your mouse.
Curves and coating of AIRE M73 is just attractive that you'll find it hard to refuse. Ergonomic design is ideal for right-handed users, while the non-slip, plastic panels on the side provide comfort and extraordinary hand-feeling that is already more than satisfying to users.
Plug-and-Play technology makes it effortless to use the mouse on different devices. Tiny nano receiver ensures great experience of traveling with your notebook all the time!
  • Eco-friendly - easy power-shut
  • Sapphire blue optical sensor
    The mouse is so responsive and easy to control. You will find the precision of tracking beyond your imagination.
  • Internet backward and forward buttons
    Use these Internet backward and forward buttons when browsing web pages, and feel the convenience brought by them!
  • Long battery life
    With 2 AAA batteries, AIRE M73 is able to work for you for 7 months! With the "Easy Power-Shut" design, the battery life can last even longer! Let's go green and save energy together.
  • Stylish design and comfortable grip
  • High quality scrolling wheel
    Enlarged high-quality 3D scrolling wheel makes it even more comfortable when you surf the pages. What's more, the design of the scrolling wheel is stylish and charming!
  • Low-power indicator
    When the battery is low, the low-power indicator would blink for 5 seconds, and then turn off.
  • Portable nano receiver
Gigabyte AIRE M73 - mouse - 2.4 GHz - elegant matte black
Mouse
Wireless - 2.4 GHz
Elegant matte black
Orientation
Right-handed
7.6 cm x 12.3 cm x 4.3 cm
91 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
5
Movement Resolution
1000 dpi
Programmable buttons, scrolling wheel, battery indicator, on/off power switch, anti-slip side panels
AAA type
Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Microsoft Windows XP 32-bit
Mouse
Wireless Receiver
Orientation
Right-handed
7.6 cm
12.3 cm
4.3 cm
91 g
Elegant matte black
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 8 m
Optical
Buttons Qty
5
Movement Resolution
1000 dpi
1 x USB - 4 pin USB Type A
Plug and Play, BSMI, FCC, NCC
AAA type
Run Time (Up To)
7 months
