Save your power anytime! The thoughtful design of on-the-top power key makes it more intuitive to power your mouse.
Curves and coating of AIRE M73 is just attractive that you'll find it hard to refuse. Ergonomic design is ideal for right-handed users, while the non-slip, plastic panels on the side provide comfort and extraordinary hand-feeling that is already more than satisfying to users.
Plug-and-Play technology makes it effortless to use the mouse on different devices. Tiny nano receiver ensures great experience of traveling with your notebook all the time!
Eco-friendly - easy power-shut
Save your power anytime! The thoughtful design of on-the-top power key makes it more intuitive to power your mouse. -
Sapphire blue optical sensor
The mouse is so responsive and easy to control. You will find the precision of tracking beyond your imagination. -
Internet backward and forward buttons
Use these Internet backward and forward buttons when browsing web pages, and feel the convenience brought by them! -
Long battery life
With 2 AAA batteries, AIRE M73 is able to work for you for 7 months! With the "Easy Power-Shut" design, the battery life can last even longer! Let's go green and save energy together. -
Stylish design and comfortable grip
Curves and coating of AIRE M73 is just attractive that you'll find it hard to refuse. Ergonomic design is ideal for right-handed users, while the non-slip, plastic panels on the side provide comfort and extraordinary hand-feeling that is already more than satisfying to users. -
High quality scrolling wheel
Enlarged high-quality 3D scrolling wheel makes it even more comfortable when you surf the pages. What's more, the design of the scrolling wheel is stylish and charming! -
Low-power indicator
When the battery is low, the low-power indicator would blink for 5 seconds, and then turn off. -
Portable nano receiver
- Gigabyte AIRE M73 - mouse - 2.4 GHz - elegant matte black
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Elegant matte black
- Orientation
- Right-handed
- 7.6 cm x 12.3 cm x 4.3 cm
- 91 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Buttons Qty
- 5
- Movement Resolution
- 1000 dpi
- Programmable buttons, scrolling wheel, battery indicator, on/off power switch, anti-slip side panels
- Battery
- AAA type
- OS Required
- Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Microsoft Windows XP 32-bit
- 2-year warranty
- Mouse
- Wireless Receiver
- Orientation
- Right-handed
- 7.6 cm
- 12.3 cm
- 4.3 cm
- 91 g
Input Device
- Wireless
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 8 m
- Optical
- Buttons Qty
- 5
- 1000 dpi
- 1 x USB - 4 pin USB Type A
- Plug and Play, BSMI, FCC, NCC
- AAA type
- Run Time (Up To)
- 7 months
- OS Required
- Limited warranty - 2 years
