The cutting-edge laser tracking system permits ultimate experience – it works on almost every surface, including glass desk, lacquered desk, ice, and sofa. Take it anywhere you want to go, and feel the smooth motion.
Rechargeable battery system
The M93 ICE is equipped with a rechargeable Ni-MH battery for long lasting continued use. Use the micro-USB cable to charge your mouse. -
Free-scrolling technology
Gigabyte free-scrolling Technology facilitates webpage browsing and boosts efficiency. Easily move your webpage or file up and down, left and right by pressing the free-scrolling key. -
4-direction tilt wheel functionality
Versatile 4-direction tilt wheel for quick and easy desktop navigation. -
Programmable 4 & 5 key
You may download GIGABYTE software from the official website, and then change button functions to suit your needs with simple clicks. Personalizing mouse button function is like mouse make-over. It helps to boost work efficiency, and make your mouse one of a kind! -
On-the-fly DPI adjustable
You may adjust DPI sensitivity between 1200 and 2000 anytime by simply clicking DPI-adjusting button on the mouse. -
Incredible hand-feeling & stylish design
The M93 ICE stays true to Gigabyte’s core concept – ergonomic design. The mouse is ideal for right-hand users. The modern design of the mouse is stunning, along with its unique bottom shape.
- Gigabyte AIRE M93 ICE - mouse - 2.4 GHz - black
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Black
- Orientation
- Right-handed
- 7.1 cm x 11.3 cm x 4.2 cm
- 90 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Laser
- Buttons Qty
- 7
- Movement Resolution
- 2000 dpi
- Performance
- Realtime sensitivity switching 1200/2000 dpi
- Programmable buttons, scrolling wheel (4-way), GIGABYTE Free-Scrolling Technology, GIGABYTE ICE Technology
- Battery
- AA type
- OS Required
- Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Microsoft Windows XP 32-bit
- 2-year warranty
- Mouse
- Wireless Receiver
- Orientation
- Right-handed
- 7.1 cm
- 11.3 cm
- 4.2 cm
- 90 g
- Black
Input Device
- Wireless
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 10 m
- Laser
- Buttons Qty
- 7
- 2000 dpi
- Performance
- 1 x USB - 4 pin USB Type A
- Included Accessories
- Micro-USB cable
- BSMI, FCC, NCC
- AA type
- Technology
- Nickel Metal Hydride
- Capacity
- 2100 mAh
- Run Time (Up To)
- 3 months
- OS Required
- Limited warranty - 2 years
