Designed particularly for professional AV applications the Modular Series includes excellent features that reduce installation time and maximize versatility.
Versatile mounting
Designed specifically for projectors, the Peerless Modular Series Projector Mount Adaptor offers a secure and versatile mounting solution. This component ensures your projector is perfectly positioned for optimal viewing angles and image clarity. -
Seamless integration
The sleek design of the Peerless Modular Series Projector Mount Adaptor seamlessly integrates with any decor. Its compatibility with a wide range of projectors makes it an ideal choice for both home and professional settings.
- Peerless Modular Series Projector Mount Adaptor mounting component - for projector - black
- Product Type
- Mounting component
- Mounting Components
- Threaded pole adapter
- 3.81 cm
- Recommended Use
- Projector
- Max Load Weight
- 29.9 kg
- Black
- 3.81 cm
- Black
AV Furniture
- Recommended Use
- Projector
- Max Load Weight
- 29.9 kg
