Generic GRYPHON M4100-BLACK - 433MHZ
Quicklinx: 755XWS00 Mfr#: GM4100-BK-433
The Gryphon family represents the premium line of Datalogic scanning's general purpose handheld data collection products. The Gryphon GM4100 cordless linear imaging readers offer the richest feature set among general purpose product offerings.
Extremely versatile and durable, the Gryphon GM4100 cordless linear imaging readers are the ultimate solution for applications in retail and light industrial environments where mobility is necessary for improved productivity. Mobile communications also eliminate the restraints caused by cabled devices, providing a safer and more efficient environment for employees.
Narrow band radio communications with Datalogic's STAR Cordless System is the key to increased productivity and flexibility in the workplace. The GM4100 reader series offer scalable solutions from simple point-to-point applications to networking capabilities combined with seamless roaming for complex installations.
Datalogic's patented 2-position cradle (CRADLE NOT INCLUDED) provides multiple solutions to answer different functional and reduced space requirements. It provides hands-free reading capabilities and a scan-while-charging feature to ensure constant up-time for increased productivity.
GM4100 batch mode capability allows thousands of codes to be stored in memory. This feature combined with a long lasting 50K scans per charge Lithium-Ion battery allows unlimited mobility and reliable data collection when out-of-range from the base station.
Featuring Datalogic's exclusive patented `Green Spot' for good read feedback directly on the code, it helps to improve productivity especially in noisy environments. When using the product with the cradle at a 45° position, the green spot can work as an aiming system remaining on to aid in positioning the code for quick and intuitive reading.
  • Efficient scanning
    Equipped with a linear imager scan element, the Datalogic Gryphon I GM4100 delivers reliable single-pass scanning, ensuring quick and accurate data capture.
  • Durable design
    Designed to withstand the rigors of daily use, this barcode scanner boasts a drop specification of 1.8 m to concrete, complemented by an IEC 60529 IP52 rating for dust and water resistance.
  • Optimal compatibility
    With PC compatibility, the Datalogic Gryphon I GM4100 seamlessly integrates into existing systems, making it a versatile choice for a wide range of applications.
  • User-friendly notifications
    The device enhances user efficiency with immediate feedback through an LED indicator and beeper for successful scans, facilitating a smooth operational flow.
  • Extended operational range
    Thanks to its wireless connectivity technology and a robust lithium-ion battery, users enjoy the freedom to scan barcodes far from the base station, ensuring flexibility in various work environments.
Datalogic Gryphon I GM4100 - barcode scanner
Barcode scanner - portable - RF - decoded
Minimum Bar Width
3 mil
Scan Element Type
Linear imager
Scan Speed
325 scan / sec
Wireless
Wireless Connectivity
RF
1 x Lithium Ion
7.1 cm x 10 cm x 18.1 cm
3-year warranty
Barcode
Interface Type
RF
Minimum Bar Width
3 mil
Scan Element Type
Linear imager
Light Source Wave Length
630-670 nm
Scan Mode
Single-pass
Scan Speed
325 scan / sec
Max Working Distance
80 cm
Skew (Degrees)
65
Pitch (Degrees)
65
Print Contrast Signal (PCS)
15%
Decode Capability
GS1 DataBar, China Post
TTL Decoding
Decoded
Wireless
OK Notification
Beeper, LED indicator
RF
Display
Display Resolution
96 x 32
Character Resolution
4 lines x 16 characters
1 x radio
RoHS, IEC 60529 IP52, IEC 60825-1
1 x Lithium Ion
7.1 cm
10 cm
18.1 cm
Limited warranty - 3 years
50 °C
5 - 95%
Drop Specification
1.8 m to concrete
