Generic Datalogic Quickscan M2130
Quicklinx: 6P6PWS00 Mfr#: QM2130-BK-433
Datalogic Scanning offers Datalogic's QuickScan Mobile reader, a small and light-weight linear imager product equipped with the Datalogic Scanning STAR radio (910MHz), the markets most secure and reliable cordless communication system.
The QuickScan Mobile reader combines outstanding performance and an affordable price to provide a breakthrough product in the AIDC industry by offering the best return on investment solution in its class for retail and commercial applications. This solution provides a cost effective alternative to traditional corded scanner solutions making cordless scanning an option for an expanded number of customers.
The superior range of Datalogic Scanning's STAR radio allows the QuickScan Mobile reader to be used for standard checkout activities as well as for price checking or inventory operations. The same scanner can be used for front-end and back-store applications.
The QuickScan Mobile reader includes an auto-sensing base station/stand providing hands-free scanning with the added benefit of charging the battery while using the hand-held reader as a presentation scanner.
  • Efficient scanning
    Equipped with a visible laser diode, the Datalogic QuickScan M2130 barcode scanner delivers a scan speed of 235 scans per second, ensuring quick and reliable barcode reading for a variety of applications.
  • Durable design
    Designed to withstand the rigors of daily use, this scanner boasts a drop specification of 1.5 m to concrete, making it a resilient tool for any busy environment.
  • Versatile compatibility
    With PC compatibility and decoded TTL, the Datalogic QuickScan M2130 seamlessly integrates into existing systems, providing a Plug-and-Play solution for immediate use.
  • Advanced technology
    Featuring Puzzle Solver Technology and the ability to read a wide range of barcodes including GS1 DataBar and Reduced Space Symbology (RSS), this scanner is equipped to meet the demands of modern retail and logistics operations.
  • Environmental resilience
    The scanner's robust design is complemented by its ability to operate within a wide range of temperatures (0°C to 40°C) and humidity (0 - 90%), ensuring reliable performance in various working conditions.
Datalogic QuickScan M2130 - barcode scanner
Barcode scanner - handheld - RF - decoded
Europe
Scan Element Type
Visible laser diode
Scan Speed
235 scan / sec
Wireless
Wireless Connectivity
RF
1 x Lithium Ion
11.4 cm x 6.4 cm x 14 cm
136 g
3-year warranty
Europe
Barcode
Interface Type
RF
Scan Element Type
Visible laser diode
Light Source Wave Length
630-670 nm
Scan Speed
235 scan / sec
Max Working Distance
20 cm
Print Contrast Signal (PCS)
20%
Decode Capability
Code 93, Code 39, UCC/EAN-128, Code Delta IBM, ISBT 128, ISBN, GS1 DataBar, Telepen, Code 32, Codabar, Code 128, Code 11, Code 16K, Code 2 of 5, MSI-Plessey, ISSN
TTL Decoding
Decoded
Wireless
OK Notification
Beeper, LED indicator
Reduced Space Symbology (RSS), waterproof, Puzzle Solver Technology
RF
1 x USB , 1 x keyboard wedge , 1 x RS-232 , 1 x wand
Cradle
TUV, RoHS, EN 60825
1 x Lithium Ion
Software
Software Included
Datalogic Aladdin
11.4 cm
6.4 cm
14 cm
136 g
Limited warranty - 3 years
0 - 90%
Drop Specification
1.5 m to concrete
