Optical gaming mouse with ergonomic design
Optical Sensor
Maximum tracking power for precision navigation
64K (Onboard Memory)
Plug & play on different PCs storing 3 profiles, macro assignments, and muscle memory achievements
2000 DPI
2000 DPI for pixel perfect accuracy
6 Smart Keys
6 keys with 5 available keys for strategic assignment of macros, profiles, keyboard keys, media controls, windows functions... etc
Polling Rate (1000 Hz)
Selectable polling rate 125 / 250 / 500 / 1000 Hz
10 millon click (Lifecycle)
Heavy-duty 10 million click lifecycle
Weight System - N/A
Cable Length - 2M
Keys - 5+1 Keys
Resolution - up to 2000 DPI
Polling Rate - 125 / 250 / 500 /1000 Hz
Onboard Memory - 64K
Dimension(LxWxH) - 119.3 x 63.5 x 40.3 mm
Tracking Method - Advanced Gaming Optical Sensor
Switch Lifecycle - 10 Million
Graphical UI - Yes (GAMDIAS HERA)
- Gamdias DEMETER GMS5000 - mouse - USB
- Mouse
- Connectivity Technology
- Wired - USB
- 6.35 cm x 11.93 cm x 4.03 cm
- Movement Detection Technology
- Optical
- Buttons Qty
- 6
- Movement Resolution
- 2000 dpi
- Performance
- 125/250/500/1000 reports per second
- Programmable buttons, illuminated scrolling wheel, Macros, Teflon feet, rubber coating, anti-slip
- Cable Length
- 2 m
- Mouse
- 6.35 cm
- 11.93 cm
- 4.03 cm
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 6
- Memory
- 64 KB
- 2000 dpi
- Performance
- Cable Length
- 2 m
- 1 x USB - 4 pin USB Type A
- Plug and Play
- Software Included
- GAMDIAS HERA
