Gainward GeForceGTX 6904GB: The fastest graphics card on the planet
Smoothest: Count on NVIDIA gaming innovations like new hardware-based frame metering, ultra-fastTXAA/FXAA antialiasing, andAdaptive Vertical Sync for an ultra-smooth gaming experience.
Fastest: Experience the ultimate combination of dual-GPU power and advanced technologies like NVIDIA® GPU Boost and Quad NVIDIA SLI®, designed to deliver raw gaming performance
Richest: Crank up NVIDIA Surround TMmulti-monitor gaming or VIDIA 3D Vision® Surround technology with NVIDIA PhysX® in full 1080 HD on a single graphics card.
Spec
- Product Name : Gainward GeForce® GTX 690 4GB
- GPU : GeForce GTX 690
- GPU Clockspeed : 1019 MHz (boost) / 915 MHz (base)
- Memory : 4096MB GDDR5 (512 bits)
- Memory Clockspeed : 3004 MHz (DDR6008)
- Bandwidth : 384.5 GB/s
- Ramdac : 400 MHz
- Bus : PCI-Express 3.0
- Cooling : 2 Slot Fan cooler
- Connectivity : 3-DVI, mini DisplayPort
- Product Size : 280mm x 112mm
- Power Connector : 8-pin *2
Key Features
- Keplerarchitecture
- NVIDIA GPU Boost
- NVIDIA Adaptive Vertical Sync
- NVIDIA TXAA and FXAA technology
- Microsoft DirectX 11 with DirectCompute5.0 support
- NVIDIA PhysXtechnology
- NVIDIA CUDA technology
- NVIDIA 3D Vision Ready
- NVIDIA Quad SLI Ready
- NVIDIA Surround
- PCI Express 3.0 support
- OpenGL 4.2 and OpenCLSupport
- Support for four concurrent displays including: DisplayPort1.2, DVI *3 (dual-link)
Output Support
- DVI *3, mini DisplayPort#
Dimensions
- PCB: 280mm(L)x112mm(W)
- Cooler :2 slot
- Bracket: 2 slot
Accessory
- 1.Driver CD
- 2.Manual
- 3.Power cable
Minimum System, Requirements
- PCI Express-compliant motherboard with one dual-width x16 graphics slot
- Two 8-pin PCI Express supplementary power connectors
- Minimum 650W or greater system power supply (with a minimum 12V current rating of 48A)
- Microsoft Windows 7, Windows Vista
Smoothest
Count on NVIDIA gaming innovations like hardware-based frame metering, ultra-fast TXAA/FXAA antialiasing, and adaptive vertical sync for an ultra-smooth gaming experience. -
Fastest
Experience the ultimate combination of dual-GPU power and advanced technologies like NVIDIA GPU Boost and Quad NVIDIA SLI, designed to deliver raw gaming performance. -
Richest
Crank up NVIDIA Surround multi-monitor gaming or VIDIA 3D Vision Surround technology with NVIDIA PhysX in full 1080 HD on a single graphics card.
