Func HS-260 Gaming Headset
Quicklinx: B265WS00 Mfr#: FUNC HS-260-1ST
The HS-260 has been designed to help you through long gaming sessions with comfortable, breathable ear cups and an extremely accurate sound image. The closed ear cup design blocks background noise allowing you to stay focused on your game, while the controls are located on the ear cup for easy access allowing you to keep your eyes focused on the screen with minimal distractions. The added features of the removable microphone and detachable cord solution ensure that you have a well-rounded, multi-functional gaming headset.
  • Intuitive control interface integration
    The HS-260 has been designed with the sound and volume controls directly integrated onto the headset itself. When these controls are found on an in-line control piece on the headphone cord, it tends to get stuck on your table, chair or wrapped up in your clothes. With the controls being directly integrated onto the headset, it helps to eliminate distractions such as looking for the volume/mute control while you are in situations of life and death; taking your eyes off the screen can be detrimental at this point.
  • Tuned and paired 50 mm drivers sound optimized for gaming
    A larger driver tends to deliver a more powerful sound, which in turn delivers a deeper bass. As well, the sound images get a greater resolution in terms of audio which means that you will be able to hear and distinguish a more detailed sound image. The drivers have been carefully tuned to deliver a well balanced sound image. This will allow you to achieve a distinguished speech as well as a full audio experience during gaming sessions. The speakers have been synced to work at the same performance level which will help you to pinpoint the exact position of an enemy in-game.
  • Detachable cord and microphone solution
    Convert the headset to headphones thanks to the detachable microphone. The microphone and audio cable can be connected on either side of the headphones as they are removable and will work in both positions.
func HS-260 - headset
Headset - wired
Recommended Use
Game console, computer
Headphones Form Factor
Full size binaural
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Impedance
32 Ohm
Microphone
Detachable - boom
Controls
Volume, answer/end
Headset - wired
18 cm
10.5 cm
19.4 cm
0.37 kg
Recommended Use
Audio Output
Full size binaural
Headphones Cup Type
Closed
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Impedance
32 Ohm
Diaphragm
50 mm
Microphone
Boom
Remote Control
Controls
Volume, answer/end
Connector Type
Headphones (mini-phone stereo 3.5 mm) , Microphone (mini-phone 3.5mm)
Cable
Detachable Cable
Cable Details
Headset cable - 3 m
