Fujitsu USB 3.0 Gigabit LAN Adapter
Quicklinx: 977QWS00 Mfr#: S26391-F6055-L520
The Fujitsu USB 3.0 Gigabit LAN adapter allows you to connect your computer to a 10/100/1000 Mbps network simply by a USB port. It provides an additional system independent network controller and is ideal for any environment lacking wireless availability.
Fujitsu USB 3.0 Gigabit LAN Adapter - network adapter - USB 3.0 - Gigabit Ethernet
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
2.1 cm x 1.6 cm
Length
19 cm
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 3.0
Black, silver
Microsoft Windows Vista / XP / 7 / 8, Windows 8.1
Celsius J550, J580; CELSIUS Mobile H970; ESPRIMO D538/E94, D738/E94, D958, D958/E94, Q956, X923; LIFEBOOK A514, A555, E544, E554, E733, E734, E743, E744, E752, E753, E754, E782, P702, P772, S752, S762, S782, S792, S904, S935, SH531, T725, T732, T935, U745, U904; Stylistic Q572, Q584, Q702, Q704
Network adapter
External
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Status Indicators
Link/activity
Remote Wake Up, USB powered, PXE support, suspend mode
1 x 1000Base-T - RJ-45
1 x USB cable (integrated)
FCC Class B certified
Black, silver
Software Included
Drivers & Utilities
2.1 cm
1.6 cm
Length
19 cm
70 °C
Fujitsu Celsius J550/2-L, J580 , Fujitsu CELSIUS Mobile H710, H710 proGREEN selection, H970 , Fujitsu ESPRIMO D538/E94+, D738/E94+, D958/E85+, D958/E94+, Q956/MRE, X923-T , Fujitsu LIFEBOOK A514, A555, E544, E554, E733, E734, E743, E744, E751, E751 proGREEN, E752, E752 Office Selection, E753, E754, E782, E782 Channel, E782 Performance Selection, E782 proGREEN, LH532, P701, P701 security selection, P702, P702 Security Selection, P770, P771, P772, P772 SC, S751, S751 proGREEN, S752, S752 Office Selection, S760, S761, S761 Security selection, S762, S782, S782 Channel, S782 Performance Selection, S782 proGREEN, S792, S792 Performance Selection, S792 Security Selection, S904, S935, SH531, SH531/GFX, T580, T725, T730, T731, T731 Security selection, T732, T900, T901, T901 Security selection, T935, U745, U904 , Fujitsu Stylistic Q550, Q572, Q584, Q702, Q704
977Q C2G 2m USB 2.0 A/B Cable - Black In Stock £3.60
