The Fujitsu USB 3.0 Gigabit LAN adapter allows you to connect your computer to a 10/100/1000 Mbps network simply by a USB port. It provides an additional system independent network controller and is ideal for any environment lacking wireless availability.
- Fujitsu USB 3.0 Gigabit LAN Adapter - network adapter - USB 3.0 - Gigabit Ethernet
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- SuperSpeed USB 3.0
- Ports
- Gigabit Ethernet
- 2.1 cm x 1.6 cm
- Length
- 19 cm
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1 Gbps
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 3.0
- Black, silver
- System Requirements
- Microsoft Windows Vista / XP / 7 / 8, Windows 8.1
- Designed For
- Celsius J550, J580; CELSIUS Mobile H970; ESPRIMO D538/E94, D738/E94, D958, D958/E94, Q956, X923; LIFEBOOK A514, A555, E544, E554, E733, E734, E743, E744, E752, E753, E754, E782, P702, P772, S752, S762, S782, S792, S904, S935, SH531, T725, T732, T935, U745, U904; Stylistic Q572, Q584, Q702, Q704
- Network adapter
- Form Factor
- External
- Ports
- Gigabit Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- Status Indicators
- Link/activity
- Remote Wake Up, USB powered, PXE support, suspend mode
- 1 x 1000Base-T - RJ-45
- Cables Included
- 1 x USB cable (integrated)
- FCC Class B certified
- Black, silver
- Software Included
- Drivers & Utilities
- OS Required
- 2.1 cm
- 1.6 cm
- Length
- 19 cm
- 0 °C
- 70 °C
- Designed For
- Fujitsu Celsius J550/2-L, J580 , Fujitsu CELSIUS Mobile H710, H710 proGREEN selection, H970 , Fujitsu ESPRIMO D538/E94+, D738/E94+, D958/E85+, D958/E94+, Q956/MRE, X923-T , Fujitsu LIFEBOOK A514, A555, E544, E554, E733, E734, E743, E744, E751, E751 proGREEN, E752, E752 Office Selection, E753, E754, E782, E782 Channel, E782 Performance Selection, E782 proGREEN, LH532, P701, P701 security selection, P702, P702 Security Selection, P770, P771, P772, P772 SC, S751, S751 proGREEN, S752, S752 Office Selection, S760, S761, S761 Security selection, S762, S782, S782 Channel, S782 Performance Selection, S782 proGREEN, S792, S792 Performance Selection, S792 Security Selection, S904, S935, SH531, SH531/GFX, T580, T725, T730, T731, T731 Security selection, T732, T900, T901, T901 Security selection, T935, U745, U904 , Fujitsu Stylistic Q550, Q572, Q584, Q702, Q704
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £3.60 |
