Fujitsu TX1330 Intel Xeon E3 1220V1 8GB NO HDD
Quicklinx: 9QBPWS00 Mfr#: VFY:T1331SC020IN
  • Xeon
The Fujitsu Server PRIMERGY TX1330 M1 is the ideal, robust and cost-efficient server for SMBs or branch offices. It scores with the best Intel Xeon E3 family performance, and solid expandability thanks to hot-plug hard disks, and full server management support. The PRIMERGY TX1330 M1: an excellent long-term investment.
Fujitsu PRIMERGY TX1330 M1 - tower - Xeon E3-1220V3 3.1 GHz - 8 GB - no HDD
Server - tower
Height (Rack Units)
4U
Region: India, Asia Pacific, EMEA
Server Scalability
1-way
1 x Intel Xeon E3-1220V3 / 3.1 GHz (, up to 3.5 GHz, (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
8 MB L3 Cache
Cache Per Processor
8 MB
RAM
8 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s); SATA
Server Storage Bays
Hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
DVD SuperMulti
GigE
Power Redundancy
Optional
Software Included
ServerView
17.7 cm x 56 cm x 45.5 cm
Limited warranty - 1 year - on-site
Server
Product Form Factor
Tower - 4U
Server Scalability
1-way
Front Accessible Bays Qty
3
Hot-Swap Bays Qty
4
Processor / Chipset
CPU
Clock Speed
3.1 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel C224
Cache Memory
Installed Size
L3 Cache - 8 MB
Cache Per Processor
8 MB
RAM
Installed Size
8 GB / 32 GB (max)
DDR3 SDRAM - ECC
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
Unbuffered, dual rank
Configuration Features
1 x 8 GB
Hard Drive
No HDD
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Channel Qty
4
RAID Level
RAID 0, RAID 1, RAID 10
Storage Controller (2nd)
Channel Qty
2
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel I217, I210
Remote Management Protocol
IPMI 2.0
Remote Management Controller
Integrated Remote Management Controller (iRMC S4)
Wake on LAN (WoL), PXE support
Bays
4 (total) / 4 (free) x hot-swap 3.5" , 3 (total) / 2 (free) x external 5.25"
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x memory , 2 (total) / 2 (free) x PCIe 3.0 x8 , 1 (total) / 1 (free) x PCIe 2.0 x4 (x1 mode) , 1 (total) / 1 (free) x PCIe 2.0 x8 (x4 mode)
6 x USB 2.0 (1 front, 4 rear, 1 internal) , 4 x USB 3.0 (1 front, 2 rear, 1 internal) , 1 x VGA , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x management
FCC Class A certified, VCCI, C-Tick, BSMI, GS, CB, CCC, RoHS, WEEE, cULus, GOST-R, KC, cCSAus
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
450 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
94%
Operating System / Software
Software
ServerView
17.7 cm
56 cm
45.5 cm
10 °C
35 °C
10 - 85% (non-condensing)
Sound Emission
25 dBA
9QBP C2G 2m USB 2.0 A/B Cable - Black In Stock £4.02
