Fujitsu TX1310 LFF Xeon E3-1226V3 8GB 2x2TB
Quicklinx: 9NKXWS00 Mfr#: VFY:T1311SC030IN
  • Xeon
The Fujitsu PRIMERGY TX1310 M1 is the ideal first server for small and medium-sized businesses. With plenty of RAM and Intel Xeon processor support it offers more than enough performance for all classic server tasks, such as file, print, web or office applications. The small tower server is build for reliable 24/7 operation and guarantees data safety by high-end features like ECC memory and an onboard RAID controller. Thanks to the screwless chassis and Fujitsu's Easy Rails for hard disks the server is easy to service. Moreover, the PRIMERGY TX1310 M1 is incredibly silent making it an excellent choice for any office environment.
Fujitsu PRIMERGY TX1310 M1 - tower - Xeon E3-1246V3 3.5 GHz - 8 GB - HDD 2 x 2 TB
Server - tower
Server Scalability
1-way
1 x Intel Xeon E3-1246V3 / 3.5 GHz (, up to 3.9 GHz, (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
8 MB L3 Cache
Cache Per Processor
8 MB
RAM
8 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s); SATA
Hard Drive
2 x HDD 2 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics P4600
GigE
Software Included
ServerView
17.5 cm x 41.9 cm x 39.5 cm
14 kg
Limited warranty - 1 year - on-site
Server
Product Form Factor
Tower
Server Scalability
1-way
Internal Bays Qty
4
Front Accessible Bays Qty
2
Processor / Chipset
CPU
Clock Speed
3.5 GHz
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel C226
Cache Memory
Installed Size
L3 Cache - 8 MB
Cache Per Processor
8 MB
RAM
Installed Size
8 GB / 32 GB (max)
DDR3 SDRAM - ECC
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
Unbuffered
Configuration Features
1 x 8 GB
Hard Drive
HDD
2 x 2 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Business critical
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Channel Qty
4
RAID Level
RAID 0, RAID 1, RAID 10
Storage Controller (2nd)
Channel Qty
2
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
VGA
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel I217, I210
PXE support, Teaming support
Bays
4 (total) / 2 (free) x internal 3.5" x 1/3H , 2 (total) / 1 (free) x external 5.25"
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x memory , 2 (total) / 2 (free) x PCIe 3.0 x8 , 1 (total) / 1 (free) x PCIe 2.0 x4 (x1 mode) , 1 (total) / 1 (free) x PCIe 2.0 x8 (x4 mode)
4 x USB 2.0 (4 rear) , 5 x USB 3.0 (2 front, 2 rear, 1 internal) , 1 x VGA , 1 x serial , 2 x LAN (Gigabit Ethernet)
FCC Class A certified, CSA, VCCI, C-Tick, GS, CB, ULC, RoHS, WEEE, KC, ETSI 300 019
Power supply
Power Provided
250 Watt
80 PLUS Certification
80 PLUS Bronze
Efficiency
85%
Operating System / Software
Software
ServerView
17.5 cm
41.9 cm
39.5 cm
14 kg
10 °C
35 °C
Sound Emission
24 dBA
9NKX C2G 2m USB 2.0 A/B Cable - Black In Stock £3.59
