The FUJITSU Tablet STYLISTIC V535 enables new levels of productivity in industrial settings. It is made for rough environments thanks to a water and dust resistant yet lightweight design and combined with a 21.0 cm (8.3-inch) display with toughened glass. Ultimate connectivity and navigation options like 4G/LTE, NFC, GPS and GLONASS as well as a long battery runtime let you stay connected wherever you are. The Fujitsu Smart Shell concept is designed to fit to individual industrial requirements.
Usability
Highly adaptable for industrial and retail use with Fujitsu Shell concept: SmartCard Shell and Retail Shells as well as enterprise connectivity with WLAN, NFC and GPS. -
Durability
Designed to roll with the punches and absorb the bumps and scrapes that would normally destroy consumer-grade tablets, the Stylistic V535 tablet with its rugged case stands up to almost anything its users can throw at it. -
Mobility
Bright 8.3" WUXGA IPS panel with multi-touch input, passive pen support.
 - Fujitsu Stylistic V535 Industrial - 8.3" - Intel Atom - Z3795 - 4 GB RAM - 128 GB eMMC
- Product Type
 - Tablet - no keyboard
- Operating System
 - Win 10 Pro 64-bit
- Processor
 - Intel Atom Z3795 up to 2.39 GHz / 2 MB Cache
- Memory
 - 4 GB LPDDR3 (provided memory is soldered)
- Storage
 - 128 GB eMMC
- Display
 - 8.3" touchscreen 1920 x 1200 / WUXGA
- Graphics
 - Intel HD Graphics
- Input Device
 - Digitizer, digital pen
- Integrated Webcam
- Networking
 - 802.11a/b/g/n, Bluetooth 4.0, NFC
- Battery
 - 2-cell - up to 6.5 hours
 - Ambient light sensor, proximity sensor, digital compass, gyro sensor, 3-axis accelerometer
- Dockable
- Security
 - Trusted Platform Module (TPM 1.2) Security Chip
 - 22.78 cm x 15.01 cm x 1.25 cm
 - 540 g
- Localisation
 - Region: United Kingdom
- Environmental Standards
 - ENERGY STAR Qualified
 - Limited warranty - 2 years - pick-up and return
- Product Type
- Operating System
 - Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
 - Intel Atom Z3795
- Max Turbo Speed
 - 2.39 GHz
- Number of Cores
 - Quad-Core
- Cache
 - 2 MB
- 64-bit Computing
- RAM
 - 4 GB (provided memory is soldered)
- Technology
 - LPDDR3 SDRAM
- Speed
 - 1066 MHz
Storage
- Main Storage
 - 128 GB eMMC
Display
 - 8.3" - IPS
- Touchscreen
 - Yes (10-point multi-touch)
- Resolution
 - 1920 x 1200 (WUXGA)
- Widescreen
- Image Aspect Ratio
 - 16:10
- Image Brightness
 - 400 cd/m²
 - Glare, tempered glass
Audio & Video
- Graphics Processor
 - Intel HD Graphics
- Camera
- Resolution
 - 8 Megapixel (rear), 2 Megapixel (front)
- Camera Features
 - Autofocus, second camera
- Sound
 - Stereo speakers, stereo microphone
Input
 - Status led
Communications
- Wireless
- Wireless Controller
 - Intel Wireless-N 7265
- Technology
 - 2-cell lithium polymer
- Capacity
 - 16.48 Wh
- Run Time
 - Up to 6.5 hours
AC Adapter
- Input
 - AC 120/230 V (50/60 Hz)
- Output
 - 36 Watt, 12 V, 3 A
Connections & Expansion
- Interfaces Details
 - USB 2.0 , Headphone/microphone combo jack , Dock
- Memory Card Reader
 - Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
 - Drivers & Utilities, Adobe Reader, Fujitsu Display Manager, CyberLink Youcam, Power Saving Utility, Windows 10 Pro 64-bit recovery DVD
- Integrated Options
- Dockable
- Security
 - Administrator password, system password, water-resistant, dust-resistant, drop-resistant, UEFI BIOS, dual display support, Preboot Execution Environment (PXE) support, disinfectant ready
- Included Accessories
 - Power adapter
 - GOST, EN 60950, RoHS, WEEE, IP65
- Localization
 - 540 g
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
 - -10 °C
 - 50 °C
 - 10 - 90%
