Fujitsu ScanSnap SV600 Overhead Scanner
Quicklinx: CN0CWS00 Mfr#: PA03641-B301
Type: Overhead scanner
Form Factor: Desktop
Max Paper Size: 432 x 300 mm
Interface: USB 2.0
Compatibility: Mac, PC
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Hurry, only 1 left in stock!
£524.60 ex VAT
£629.52 inc VAT
The ScanSnap SV600 from Fujitsu for PC and Mac is a versatile overhead scanner that allows for the digitization of a range of material including newspapers, bound documents, magazines and books without the need for cutting or causing damage. Additionally it can simply and intuitively scan a variety of loose paper such as delicate information, maps, delivery notes, receipts, business cards, historical documents and blueprints.
Position the documents on the black pad and scan directly without any extra effort. The maximum document size capable of being scanned is 400 x 300 mm if the thickness of the document is more than 5 mm, and the maximum size is 432 x 300 mm if the thickness is less than 5 mm. Documents up to 30 mm thickness can be scanned.
ScanSnap's user-friendly Quick Menu can be set up to automatically appear after scanning offering a multitude of 'scan to' destinations for your scanned data thereby facilitating smooth and efficient operation. This could be sending your business cards via CardMinder to a database package, typed documents to editable Word, Excel or PowerPoint, or simply sending documents to your cloud account for viewing anywhere and anytime.
With VI technology, the SV600 ensures that scanning can be performed even without touching the document. This means that historical and aged material and documents that may be prone to damage, such as paintings, photos, and pencil or crayon drawings, can be scanned without the need for touching or being fed through a mechanism.
If you are scanning a bound document it is quick and easy to scan multiple pages quickly and smoothly - page turning detection combined with a built-in timed mode can ensure that a predetermined scan is initiated after a page turn has been detected. Book image correction automatically corrects any distortion introduced by the natural curvature of a book, for a clear, easily readable image. Additionally timed mode can be set to automatically start the scan process after a predetermined time.
In just one touch you can capture up to 10 documents of differing sizes in just one scan pass. Place several business cards, receipts and photos within the scanning area and the SV600 will capture all the documents and will intelligently crop to the exact size.
The start up time of the SV600 is very quick - just three seconds is required from start up to being scan ready and then a further three seconds to scan an A3 size document, at up to 600dpi in color. The SV600 is robust with a solid footing, yet compact enough to enable efficient usage of your workspace without imposing on your daily routines when not in use.
The bundled business card scanning software scans large volumes of business cards into digital business card holders, and enables you to transfer business card information into Excel, Outlook Express, Salesforce, and other databases for future reference.
A few simple steps to digitize and manage the information on your receipts. ScanSnap Receipt allows you to easily scan and extract information from your receipts, and export the data for other accounting software. The sophisticated features within ScanSnap Receipt automatically support various languages and currencies.
The Quick Menu can be set up to display your 'Favorite' scanning destinations or will 'Recommend' an application. Scan a business card, for example, and the SV600 will automatically recognize the card and recommend a list of installed business card-related applications.
ABBYY FineReadder for ScanSnap bundled OCR (optical character recognition) software lets you scan documents with machine print directly to editable Microsoft Word, Excel and PowerPoint format.
The bundled Nuance PDF software allows users to read directly from cloud based applications and to save directly to those cloud based applications meaning that the possibility of using and sharing digital documents is extended.
  • Energy efficient
    With its ENERGY STAR certification, this scanner meets strict energy efficiency guidelines, ensuring lower energy costs and a reduced environmental footprint. The power consumption is finely tuned with operational, sleep, and standby modes, consuming only 20 W, 2.6 W, and 0.4 W respectively.
  • Versatile scanning capabilities
    Equipped with a CCD scanning sensor and white LED light source, the scanner provides high-quality color and grayscale scanning. It supports a wide range of document sizes up to 432 x 300 mm, making it suitable for various scanning needs. Automatic image orientation, deskew, and image correction features ensure that scans are clear and accurately aligned.
  • Fast scanning speed
    Designed for efficiency, the scanner boasts a remarkable speed of 3 sec/scan across various resolutions and modes. Whether scanning in color, grayscale, or black and white, it maintains consistent performance, ensuring quick digitization of documents.
  • Advanced document handling
    The manual document feeder and desktop form factor contribute to a user-friendly scanning experience. Features like automatic color detection, page size detection, and simplex scanning streamline the scanning process, making it easier to manage documents.
  • Broad compatibility
    This scanner is designed to work seamlessly with both Mac and PC platforms, thanks to its USB 2.0 interface. The inclusion of a Type-B connector ensures easy connectivity with a wide range of devices, enhancing its versatility.
Ricoh ScanSnap - overhead scanner - desktop - USB 2.0
Overhead scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
CCD
Light Source
White LED
Max Supported Document Size
432 x 300 mm
Input Type
Optical Resolution
285 dpi x 283 dpi
Max Document Size
432 mm x 300 mm
Document Feeder Type
Manual
Microsoft Windows Vista (32/64 bits) SP2 or later, Microsoft Windows XP (32/64 bits) SP3, Apple MacOS X Lion 10.7, Microsoft Windows 7 (32/64 bits) SP1 or later, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Apple MacOS X 10.10, Windows 10 (32/64 bits), Apple MacOS X 10.11, Apple macOS 10.12
21 cm x 15.6 cm x 38.3 cm
3 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Interface Type
USB 2.0
432 x 300 mm
Scanner
Input Type
Optical Resolution
285 dpi x 283 dpi
CCD
Bulb / Light Source Type
White LED
Scanner Speed Details
3 sec/scan - colour - A3 - 150 dpi , 3 sec/scan - greyscale - A3 - 150 dpi , 3 sec/scan - black & white - A3 - 300 dpi , 3 sec/scan - colour better - A3 - 200 dpi , 3 sec/scan - greyscale better - A3 - 200 dpi , 3 sec/scan - black&white better - A3 - 400 dpi , 3 sec/scan - colour best - A3 - 300 dpi , 3 sec/scan - greyscale best - A3 - 600 dpi , 3 sec/scan - greyscale excellent - A3 - 600 dpi , 3 sec/scan - black&white excellent - A3 - 1200 dpi , 3 sec/scan - colour excellent - A3 - 600 dpi , 3 sec/scan - black&white best - A3 - 600 dpi
Scanner Features
Automatic Image Orientation, automatic colour detection, automatic page size detection, Deskew, Simplex, Image Correction
Media Handling
Max Document Size
432 mm x 300 mm
Manual
Interfaces Details
USB 2.0 - Type B
Background pad
1 x USB cable
RoHS
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
20 Watt
Power Consumption Stand by
0.4 Watt
Power Consumption Sleep
2.6 Watt
Software Included
Drivers & Utilities, ScanSnap Manager, CardMinder, Scan to Microsoft SharePoint, ABBYY FineReader for ScanSnap, ScanSnap Organizer, ScanSnap Receipt, Nuance Power PDF, Nuance Power PDF Converter (Mac), ScanSnap Sync
System Requirements Details
Windows XP/Vista/7/8/8.1/10 - Core i5 - 2.5 GHz - RAM 4 GB - HD 4200 MB (USB) , MacOS X 10.7 or later - Core i5 - 2.5 GHz - RAM 4 GB - HD 2600 MB (USB)
21 cm
15.6 cm
38.3 cm
3 kg
Limited warranty - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
CN0C Fujitsu Extends Warranty From 1 Year to 3 Year For Desktop Scanners - Inc Replacement and Shipping In Stock £63.31
CN0C Fujitsu F1 Scanner Cleaning Wipes (24 Pack) In Stock £26.99
Interface: USB 2.0
Compatibility: Mac
Compatibility: PC
Brand: Fujitsu
Price Range Ex VAT: £500 - £750
