Fujitsu ScanSnap S1500 A4 Desktop Scanner
Quicklinx: 5HDKWS00 Mfr#: PA03586-B001
The S1500 is a complete desktop solution, simply press one scanner button to convert color or mono multi page, double sided documents into digital PDF files which you can file, organize, share and email.
This intuitive scanner features 'Quick Menu' which allows users to maximize their productivity, just insert pages, press Scan, select destination function from the Quick Menu to send your scanned document to the application of your choice.
The ScanSnap S1500 comes with a linking function to popular cloud services including Dropbox, Google Docs, Evernote, SugarSync and Salesforce CRM. It is now easy to seamlessly link and save your scanned image data virtually anywhere and anytime. If no scanning interface is available Windows users can select the 'ScanSnap folder' option within the cloud application which then allows you to scan directly to the cloud through the import capability.
Scan to iPad and iPhone, and now to Android devices, via the downloadable ScanSnap Connect application. Upload your document fast, securely and easily; instantly display and share.
The ScanSnap software automatically creates Adobe PDF files which have become the de-facto standard for document exchange, enabling you to send documents anywhere in the world safe in the knowledge the recipient will see the document exactly as you see it. ScanSnap S1500 can also scan information directly into either Word, Excel or PowerPoint 2003 via OCR using the Scan2xxxx functions integrated into the ScanSnap software or drag and drop files within ScanSnap Organizer to convert to Word, Excel or PowerPoint 2003 editable documents.
To make scanning as simple as possible, ScanSnap inspects each document to decide if a document should be scanned in black and white or color, what the size of the page being scanned is and eliminate blank pages, all of which serve to speed the scanning operation and minimize your storage requirements. In addition each document will have misaligned text corrected (Auto Deskew) and each page will have its orientation automatically adjusted.
Using the supplied carrier sheet provides A3 scanning capability, A3 pages are folded and placed in the carrier sheet, when scanned, ScanSnap will automatically stitch the 2 (front & back) images together to recreate the full A3 image. The carrier sheet can also be used for scanning photos/documents which might be easily scratched or irregular shaped documents which are difficult to feed otherwise and may cause paper jams.
ScanSnap incorporates a 50 page automatic document feeder, duplex capability and color scanning within a surprisingly small footprint and is supplied with a full version of Adobe Acrobat X Standard.
  • Easily transform paper with the touch of a button
    Organizing with the ScanSnap S1500 happens at the touch of a single button. All this intelligent technology working behind the scenes ensures your PDF or JPEG files look their best automatically.
  • Intelligent speed
    There's speed and then there's speed with quality. The ScanSnap S1500 has been engineered to deliver even faster performance with up to 20 pages per minute in color, grayscale, or black and white; however, S1500 remains just as fast when scanning at a higher resolution of 200 and even 300 dpi color or grayscale.
  • Intelligent ease of use
    ScanSnap S1500 has several automatic features to help ensure scans look their best without operator intervention before or after they scan.
  • Intelligent paper feed detection
    ScanSnap S1500 is now equipped with an ultrasonic multi-feed detection sensor that can be turned on to help operators avoid losing images. What's more, an interactive interface allows users to easily and quickly bypass intentional double-feeds such as a taped-receipt on an expense report.
Fujitsu ScanSnap S1500 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Dual CCD
Max Supported Document Size
216 x 863 mm
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
20 ppm (mono) / 20 ppm (colour)
Max Document Size
216 mm x 863 mm
Automatic Duplexing
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
29.2 cm x 15.9 cm x 15.8 cm
3 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
216 x 863 mm
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Dual CCD
Max Document Scan Speed B/W
20 ppm
Max Document Scan Speed Colour
20 ppm
Scanner Speed Details
20 ppm - black & white - A4 - 300 dpi , 40 ipm - duplex - A4 - 300 dpi , 20 ppm - colour - A4 - 150 dpi , 40 ipm - duplex - colour - A4 - 150 dpi
Scanner Features
Ultrasonic Double Feed Detection
Media Handling
Max Document Size
216 mm x 863 mm
Supported Document Size Details
ADF
Automatic
50 sheets
USB 2.0 - Type B
RoHS
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
35 Watt (4.5 Watt)
Software Included
ScanSnap Organizer 4.1, CardMinder 4.1, ABBYY FineReader for ScanSnap 4.1, ScanSnap Manager 5.1, Scan to Microsoft SharePoint 3.4, Evernote for Windows 4.4, Adobe Acrobat X Standard
29.2 cm
15.9 cm
15.8 cm
3 kg
5 °C
35 °C
20 - 80%
