At nearly half the size of a sheet of paper, the ScanSnap S1300i is built for convenience and ease of use, a one button approach allows for scanning of multi-page double-sided documents whether at the desk or on the road. Stack up to 10 pages into the automatic document feeder (ADF) and press the blue button.
ScanSnap S1300i scans both sides of each page at up to 12 pages per minute directly to PDF, searchable PDF, JPEG, or to office applications like Word or Excel. The ScanSnap S1300i automatically recognizes the size of each document, detects and corrects for skew, and shows images in their proper orientation. You can even choose to have blank pages automatically removed.
ScanSnap S1300i comes with an AC Adapter but for added mobile convenience, the ScanSnap S1300i can be powered though the computer's USB ports when an AC power source is not available.
The S1300i supports wireless scanning to iPad, iPhone, Android and Kindle devices for convenient viewing via the mobile app ScanSnap Connect Application.
The S1300i can link to cloud services Dropbox, Evernote, Google Docs, Salesforce CRM and SharePoint Online (for Windows). It also brings some additional cloud syncing functions: Scan to SugarSync and Scan to Salesforce Chatter as well as Scansnap folder for Win OS only where you can scan into your preferred cloud service when no scan interface is available through the import capability.
With the bundled ScanSnap Sync built into ScanSnap Organizer software and the ScanSnap Connect app, captured documents can be automatically synchronized with all your devices through Dropbox, Google Drive or Microsoft OneDrive.
The bundled ScanSnap Receipt software allows you to easily scan and extract information from your receipts, and even export the data for tax filing.
Fast scanning with portability
At nearly half the size, the ScanSnap S1300i is the smallest multi-page, duplex capable ScanSnap for scanning on the road or at the desk. -
Intelligent scan correction
ScanSnap converts disorganization into order with intelligent features that work behind the scenes to correct images so you don't have to. -
Fast double-sided scanning
Just press the "SCAN" button and the 10 page automatic document feeder scans both sides of each page at up to 12 pages per minute. That's up to 50% faster than before. -
Compatible with PC or Mac
The ScanSnap S1300i works on both Mac and PC operating systems, making flexibility and portability a breeze. -
USB Bus power for ultimate portability
The ScanSnap S1300i can be powered by the PC or Mac's USB port when an AC power source is not available. -
ScanSnap Receipt
The ScanSnap Receipt software allows you to easily scan and extract information from your receipts, and even export the data for tax filing. -
ScanSnap Sync
With ScanSnap Sync built into ScanSnap Organizer software and the ScanSnap Connect app, captured documents are automatically synchronized with all your devices through Dropbox, Google Drive or Microsoft OneDrive.
- Fujitsu ScanSnap S1300i - document scanner - portable - USB 2.0
- Document scanner - portable
- Interface Type
- USB 2.0
- Scan Element Type
- Contact Image Sensor (CIS)
- Max Supported Document Size
- 216 x 863 mm
- Input Type
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 12 ppm (mono) / 12 ppm (colour)
- Max Document Size
- 216 mm x 863 mm
- Automatic Duplexing
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 10 sheets
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Apple MacOS X 10.7 Lion, Windows 8 (32/64 bits), Apple MacOS X 10.8, Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Apple MacOS X 10.10, Windows 10 (32/64 bits), Apple MacOS X 10.11, Apple MacOS X 10.12
- 28.4 cm x 9.9 cm x 7.7 cm
- 1.4 kg
- 1 year warranty
- Interface Type
- USB 2.0
- 216 x 863 mm
Scanner
- Input Type
- 600 dpi x 600 dpi
- Scan Element Type
- Max Document Scan Speed B/W
- 12 ppm
- Max Document Scan Speed Colour
- 12 ppm
- Scanner Speed Details
- 12 ppm - portrait (AC powered) (front) / black & white (back) - A4 - 300 dpi , 24 ipm - duplex - portrait (AC powered) (front) / black & white (back) - A4 - 300 dpi , 4 ppm - portrait (USB bus powered) (front) / black & white (back) - A4 - 200 dpi , 8 ipm - duplex - portrait (USB bus powered) (front) / black & white (back) - A4 - 200 dpi , 9 ppm - portrait (AC powered) (front) / colour (back) - A4 - 200 dpi , 18 ipm - duplex - portrait (AC powered) (front) / colour (back) - A4 - 200 dpi , 3 ppm - portrait (USB bus powered) (front) / colour (back) - A4 - 200 dpi , 6 ipm - duplex - portrait (USB bus powered) (front) / colour (back) - A4 - 200 dpi
- Scanner Features
- Powered by USB port
Media Handling
- Max Document Size
- 216 mm x 863 mm
- Automatic
- 10 sheets
- USB 2.0 - Type B
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 9 Watt (3.2 Watt)
- Software Included
- ScanSnap Manager, CardMinder, Scan to Microsoft SharePoint, ABBYY FineReader for ScanSnap, ScanSnap Organizer, ScanSnap Receipt, Evernote, ScanSnap Sync
- OS Required
- 28.4 cm
- 9.9 cm
- 7.7 cm
- 1.4 kg
- Limited warranty - 1 year
- 5 °C
- 35 °C
- 20 - 80%
Fujitsu Extends Warranty From 1 Year to 3 Year For Mobile Scanners - Inc Replacement and Shipping | In Stock | £40.29 |
Fujitsu F1 Scanner Cleaning Wipes (24 Pack) | In Stock | £26.99 |
Fujitsu Scanner Consumable Kit: 3541-100K | In Stock | £37.03 |
