Fujitsu Scansnap S1300
Fujitsu ScanSnap S1300
Quicklinx: 70F6WS00 Mfr#: PA03603-B001
The portable ScanSnap S1300 provides Windows and Mac users the tools to be productive and paperless... anywhere - anytime. The S1300 is a complete portable/desktop solution, simply press one scanner button to convert color or mono multi page, doubled sided documents into digital PDF files which you can file, organize, share and email.
ScanSnap S1300 can be powered either directly from the laptop USB ports or via an AC adapter, making it ideal for business people on the move - in the car, in clients premises etc. (Scanning speed is reduced when using USB power).
The S1300 is supplied with 2 versions of ScanSnap Manager one for Windows and one for Mac.
The ScanSnap software automatically creates Adobe PDF files which have become the de-facto standard for document exchange, enabling you to send documents anywhere in the world safe in the knowledge the recipient will see the document exactly as you see it. The PDFs can be made searchable, either in the background of ScanSnap Organizer or directly at scan time.
To make scanning as simple as possible, ScanSnap inspects each document to decide if a document should be scanned in black and white or color, what the size of the page being scanned is and eliminate blank pages, all of which serve to speed the scanning operation and minimize your storage requirements. In addition each document will have misaligned text corrected (Auto Deskew) and each page will have its orientation automatically adjusted.
ScanSnap S1300 incorporates a 10 page automatic document feeder, duplex capability and color scanning within a surprisingly small footprint and it can be powered directly from your laptop making it ideal for business travelers.
ScanSnap S1300 offers a Quick menu mode. Just place documents onto the input hopper and press the S1300's scan button. All pages are scanned and the user is presented Quick Menu, from where you can easily direct the resulting PDF file to either ScanSnap Organizer, Email recipients, file folders or even printing devices.
The ScanSnap S1300 comes with a linking function to popular cloud services including Google Docs, Evernote, SugarSync and Salesforce CRM. It is now easy to seamlessly link and save your scanned image data virtually anywhere and anytime.
Scan to iPad and iPhone via the downloadable ScanSnap Connect application. Upload your document fast, securely and easily; instantly display and share.
  • Performance in a compact size
    At nearly half the size, the ScanSnap S1300 is designed to be the smallest Fujitsu multi-page duplex scanner for one-button ease of use at the desk or on the road. Just press the "SCAN" button and the 10 page automatic document feeder scans both sides of each page at up to 8 pages per minute. The S1300 automatically recognizes the size of each document, detects and corrects for skew, and shows images in their proper orientation with blank pages removed.
  • Creates searchable content from your scans
    With ScanSnap, operators can remain connected with their scanned documents. The ScanSnap S1300 can automatically convert scanned data into searchable PDF files at the touch of a button. Users can also use a colored highlighter pen on a black and white document to create searchable keywords automatically.
Fujitsu ScanSnap S1300 - document scanner - portable - USB 2.0
Document scanner - portable
Interface Type
USB 2.0
Scanning Sensor Type
Contact Image Sensor (CIS)
Max Supported Document Size
216 x 863 mm
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
8 ppm (mono) / 8 ppm (colour)
Max Document Size
216 mm x 863 mm
Automatic Duplexing
Document Feeder Type
Automatic
Document Storage Capacity
10 sheets
Microsoft Windows 2000 Professional, Microsoft Windows XP, Microsoft Windows 7, Apple MacOS X 10.4, Microsoft Windows Vista, Apple MacOS X 10.6, Apple MacOS X 10.5, Apple MacOS X Lion 10.7
28.4 cm x 9.9 cm x 7.7 cm
1.4 kg
Interface Type
USB 2.0
216 x 863 mm
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Max Document Scan Speed B/W
8 ppm
Max Document Scan Speed Colour
8 ppm
Scanner Speed Details
8 ppm - portrait (AC powered) (front) / black & white (back) - A4 - 200 dpi , 16 ipm - duplex - portrait (AC powered) (front) / black & white (back) - A4 - 200 dpi , 4 ppm - portrait (USB bus powered) (front) / black & white (back) - A4 - 200 dpi , 8 ipm - duplex - portrait (USB bus powered) (front) / black & white (back) - A4 - 200 dpi , 6 ppm - portrait (AC powered) (front) / colour (back) - A4 - 200 dpi , 12 ipm - duplex - portrait (AC powered) (front) / colour (back) - A4 - 200 dpi , 3 ppm - portrait (USB bus powered) (front) / colour (back) - A4 - 200 dpi , 6 ipm - duplex - portrait (USB bus powered) (front) / colour (back) - A4 - 200 dpi
Scanner Features
Powered by USB port
Media Handling
Max Document Size
216 mm x 863 mm
Automatic
10 sheets
Interfaces Details
USB 2.0 - Type B
External power adapter
Power Consumption Operational (Standby)
9 Watt (3.2 Watt)
Software Included
Cardiris Pro 4 for Mac, ScanSnap Organizer 4.1, CardMinder 4.1, ABBYY FineReader for ScanSnap 4.1, ScanSnap Manager 5.1, Scan to Microsoft SharePoint 3.4, Evernote for Windows 4.4, Evernote for Mac 2.2, ScanSnap Manager 3.2 for Mac
28.4 cm
9.9 cm
7.7 cm
1.4 kg
Limited warranty - replacement - 2 years
5 °C
35 °C
20 - 80%
