Discover the smarter way to work, using the ScanSnap iX1500. The iX1500’s 4.3-inch LCD touchscreen turns the old way of scanning on its head; instead of scanning a document and choosing what you want to do with it each time, now, after your first simple set-up, you can forget all about it. It also allows multiple users to each personalize the interface with their own set of large, color-coded buttons for the functions they use the most. The all-new ScanSnap Home software enables you to preview, tag, search and retrieve any document easily. ScanSnap Home also uses the text on your scans – such as the shop and company name – to recommend file names by learning and adapting to how you work! ScanSnap Cloud can send them straight to one of up to four different cloud storage locations and is smart enough to recognize which one depending on the document type; photos, receipts, business cards or documents. That means instant sharing with colleagues, friends and family. The reliability of its market leading feed technology and handy receipt guide means the iX1500 makes light work of both large and small items – from A3 documents down to ID cards or receipts. Boot up and be ready to go straight away thanks to the iX1500’s fast start-up – with the touch of just one button, you’ll be scanning within seconds, just open the cover and the ScanSnap iX1500 is ready to go. The ScanSnap iX500 has a speed of 30 double-sided sheets per minute, you’ll be done in no time at all – that means more time to get on with what really matters. The iX500 can be shared out of the box with up to 4 family members or colleagues; even more with additional licenses. Connect the iX1500 directly and instantly to your computer or smart device at home or in your office: from a computer you can utilise either USB, Wi-Fi with access point connect mode, or WiFi direct connect mode and from a smart device you can use either of the two WiFi mode options.
Name files faster
ScanSnap Home uses the text, such as shop and company names, found on your scanned documents to recommend file names. Not only does accuracy of information extraction increase the more you scan, but edits made to file names are learned for later naming suggestions. -
Find files easily
ScanSnap Home offers simple yet powerful functions to organize and search all of your document types using folders, tags, and keywords. Now you can find information easier than ever before. -
ScanSnap's first 4.3 inch touch screen interface
The iX1500 comes equipped with a user-friendly touch screen, providing an easy to use interface with simple icons and an intuitive user experience. -
Time saving maintenance notifications
Receive notifications on the touch screen and from ScanSnap Home whenever Dust Detection spots dust that may result in streaked images. Maintenance notification beforehand enables you to reduce the hassle of time-consuming rescans. -
Share your ScanSnap for everyone to use
The iX1500 comes with software for multiple accounts, enabling shared use of a single unit with family members and company colleagues. -
Create files quickly
Simply open the document chute and ScanSnap is ready to go. Scan single and double sided documents with ease at a speedy 30 sheets per minute. -
Versatile paper handling
With professional grade feeding technology and ultrasonic sensors, ScanSnap handles multi-page documents with ease and can additionally detect and alert the user of multi-feeding errors. -
Scan large volumes with ease
Scan large volumes of various types of documents from color photos to double-sided landscape documents with a host of intelligent automatic image processing functions. Together, these features enable you to scan confidently without adjusting any settings. -
Scan any document
Scan documents larger than the typical A4 size that need to be folded in half, envelopes and much more with manual scan mode. Documents that are difficult to scan in normal scan mode can now be captured without any issues. -
Receipts and business cards are no longer a hassle
Effortlessly scan small documents with the receipt guide. No need to be concerned about fixing receipts and business cards that tend to curl or skew. Designed to be a comfortable fit even when the cover is closed, it dramatically reduces the handling of documents before hitting the scan button. -
Scan anywhere you want whenever you want
Connect the iX1500 to your computer or smart device at home and in your office, using existing Wi-Fi environments with access point connect mode. Connecting is also possible in environments without Wi-Fi using direct connect mode, as the scanner itself functions as an access point.
- Fujitsu ScanSnap iX1500 - document scanner - desktop - Wi-Fi, USB 3.1 Gen 1
- Document scanner - desktop
- Interface Type
- Scanning Sensor Type
- Dual CIS
- Light Source
- RGB LED array
- Max Supported Document Size
- 216 x 863 mm
- Input Type
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 30 ppm (mono) / 30 ppm (colour)
- Max Document Size
- 216 mm x 863 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, plastic card, receipts
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 7 (32/64 bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits), Apple macOS 10.12, Apple macOS 10.13, Apple macOS Mojave 10.14
- 29.2 cm x 16.1 cm x 15.2 cm
- 3.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Interface Type
- 216 x 863 mm
Scanner
- Input Type
- 600 dpi x 600 dpi
- Dual CIS
- Bulb / Light Source Type
- RGB LED array
- Max Document Scan Speed B/W
- 30 ppm
- Max Document Scan Speed Colour
- 30 ppm
- Scanner Speed Details
- 30 ppm - auto-resolution - A4 , 30 ppm - duplex - auto-resolution - A4 , 30 ppm - black & white - A4 - 300 dpi , 30 ppm - colour - A4 - 150 dpi , 30 ppm - greyscale - A4 - 150 dpi , 30 ppm - duplex - black & white - A4 - 300 dpi , 30 ppm - duplex - colour - A4 - 150 dpi , 30 ppm - duplex - greyscale - A4 - 150 dpi , 30 ppm - black&white better - A4 - 400 dpi , 30 ppm - colour better - A4 - 200 dpi , 30 ppm - greyscale better - A4 - 200 dpi , 30 ppm - duplex - black&white better - A4 - 400 dpi , 30 ppm - duplex - colour better - A4 - 200 dpi , 30 ppm - duplex - greyscale better - A4 - 200 dpi , 30 ppm - black&white best - A4 - 600 dpi , 30 ppm - colour best - A4 - 300 dpi , 30 ppm - greyscale best - A4 - 300 dpi , 30 ppm - duplex - black&white best - A4 - 600 dpi , 30 ppm - duplex - colour best - A4 - 300 dpi , 30 ppm - duplex - greyscale best - A4 - 300 dpi , 8 ppm - black&white excellent - A4 - 1200 dpi , 8 ppm - colour excellent - A4 - 600 dpi , 8 ppm - greyscale excellent - A4 - 600 dpi , 8 ppm - duplex - black&white excellent - A4 - 1200 dpi , 8 ppm - duplex - colour excellent - A4 - 600 dpi , 8 ppm - duplex - greyscale excellent - A4 - 600 dpi
- Scanner Features
- Page length detection, access point mode, Ultrasonic sensor, 4.3" touch screen TFT display
Media Handling
- Max Document Size
- 216 mm x 863 mm
- Supported Document Size Details
- ADF - up to 216 x 360 mm , Long document - up to 216 x 863 mm
- Automatic
- 50 sheets
- USB 3.1 Gen 1 - Type B
- Included Accessories
- Receipt guide
- Cables Included
- 1 x SuperSpeed USB cable
- RoHS
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 17 Watt
- Power Consumption Sleep
- 1.5 Watt
- Software Included
- ABBYY FineReader for ScanSnap, ScanSnap Cloud, ScanSnap Home, Kofax Power PDF Standard, ScanSnap Connect, Kofax Power PDF Standard for Mac
- OS Required
- System Requirements Details
- Windows 7/8.1/10 - Dual-Core Celeron - 1.8 GHz - RAM 2 GB - HD 3.8 GB , MacOS X 10.12/10.13/10.14 - Core i5 - 1.4 GHz - RAM 2 GB - HD 2 GB
- 29.2 cm
- 16.1 cm
- 15.2 cm
- 3.4 kg
- Limited warranty - 1 year
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
Fujitsu 5x Carrier Sheets for ScanSnap | In Stock | £38.09 |
Fujitsu ScanSnap Bag | In Stock | £41.27 |
Fujitsu Extends Warranty From 1 Year to 3 Year For Desktop Scanners - Inc Replacement and Shipping | In Stock | £53.71 |
Fujitsu F1 Scanner Cleaning Wipes (24 Pack) | In Stock | £26.99 |
Fujitsu Consumable Kit: 3656-200K | In Stock | £29.62 |
