Fujitsu RX100S7 E3-1220/3.1 4GB OB
Quicklinx: 7X61WS00 Mfr#: VFY:R1007SX020IN
  • Xeon
PRIMERGY RX100 S7 is designed for SMEs and data centers, looking for high availability, scalability and low TCO - in a 1U chassis. SME customers will find the RX100 S7 to be a highly versatile tool, which can be used as a web, file or print server. Data center customers can build on the RX100 S7 as a scalable entry-level virtualization platform, which offers up to Intel Xeon processor performance and onboard dual gigabit LAN. PRIMERGY RX100 S7: rack virtualization starts here!
Fujitsu PRIMERGY RX100 S7 - rack-mountable Xeon E3-1220 3.1 GHz - 4 GB - no HDD
Server - rack-mountable - mounting in asymmetrical racks
Height (Rack Units)
1U
Server Scalability
1-way
1 x Intel Xeon E3-1220 / 3.1 GHz (, up to 3.4 GHz, (Quad-Core)
Processor Socket
LGA1155 Socket
Cache Memory
8 MB L3 Cache
Cache Per Processor
8 MB
RAM
4 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC - PC3-10600
Storage Controller
SATA (SATA 6Gb/s)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
DVD SuperMulti
1GbE
Software Included
ServerView
48.3 cm x 55.7 cm x 4.3 cm
14 kg
Server
Product Form Factor
Rack-mountable - 1U
Built-in Devices
Led panel
Server Scalability
1-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
2
Processor / Chipset
CPU
Intel Xeon E3-1220
Clock Speed
3.1 GHz
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1155 Socket
Chipset Type
Intel C202
Cache Memory
Installed Size
L3 Cache - 8 MB
Cache Per Processor
8 MB
RAM
Installed Size
DDR3 SDRAM - ECC
Effective Memory Speed
1333 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
Unbuffered, dual channel memory architecture
Hard Drive
No HDD
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Channel Qty
5
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD)
CD / DVD Rewrite Speed
16x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Interfaces
VGA
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel 82574L, Intel 82579LM
Remote Management Protocol
IPMI 2.0
Remote Management Controller
Integrated Remote Management Controller (iRMC S3)
Wake on LAN (WoL), PXE support
Bays
1 (total) / 0 (free) x external 5.25" x 1/6H (Slim Line) , 2 (total) / 2 (free) x hot-swap 3.5" x 1/3H
Slots
1 (total) / 0 (free) x CPU , 4 memory , 1 (total) / 1 (free) x PCIe 2.0 x4 - low-profile (x1 mode) , 1 (total) / 1 (free) x PCIe 2.0 x8 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile
6 x USB 2.0 (2 front, 4 rear) , 1 x VGA , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x management - Ethernet 10Base-T/100Base-TX/1000Base-T
Rack mounting kit (full extraction), cable arm
Mounting in asymmetrical racks
FCC Class A certified, CSA, VCCI, C-Tick, BSMI, GOST, GS, CB, CCC, RoHS, WEEE, cULus
Power supply
Power Provided
300 Watt
Operating System / Software
Software
ServerView
48.3 cm
55.7 cm
4.3 cm
14 kg
15 °C
35 °C
10 - 85% (non-condensing)
Sound Emission
24 dBA
