The Fujitsu PRIMERGY TX2540 M1 is the perfect tower server for SMEs as well as branch offices. It supports up to two processors and combines affordable performance with balanced expandability.
- Fujitsu PRIMERGY TX2540 M1 - tower - Xeon E5-2407V2 2.4 GHz - 8 GB - no HDD
- Server - tower
- Height (Rack Units)
- 4U
- Localisation
- Region: United Kingdom
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2407V2 / 2.4 GHz (Quad-Core)
- Cache Memory
- 10 MB
- Cache Per Processor
- 10 MB
- RAM
- 8 GB (installed) / 192 GB (max) - DDR3 SDRAM - Advanced ECC - PC3-12800
- Storage Controller
- SATA (SATA 3Gb/s)
- Server Storage Bays
- Hot-swap 3.5"
- Hard Drive
- No HDD
- Optical Storage
- DVD SuperMulti
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- 17.7 cm x 65.1 cm x 45.6 cm
- Limited warranty - 3 years - on-site
- Server
- Product Form Factor
- Tower - 4U
- 2-way
- Front Accessible Bays Qty
- 3
- Hot-Swap Bays Qty
- 4
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E5-2407V2
- Clock Speed
- 2.4 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel C602
Cache Memory
- Installed Size
- 10 MB
- 10 MB
RAM
- Installed Size
- 8 GB / 192 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Registered
Hard Drive
- No HDD
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 3Gb/s
- Channel Qty
- 6
- RAID Level
- RAID 0, RAID 1, RAID 10
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Video Interfaces
- VGA
- Integrated
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- Intel I210
- Data Link Protocol
- Remote Management Protocol
- IPMI 2.0
- Remote Management Controller
- Integrated Remote Management Controller (iRMC)
- PXE support
- Bays
- 4 (total) / 4 (free) x hot-swap 3.5" , 3 (total) / 2 (free) x external 5.25"
- Slots
- 2 (total) / 1 (free) x CPU , 12 memory , 2 (total) / 2 (free) x PCIe 3.0 x8 - full-height (x4 mode) , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-height (2 processors must be installed) , 1 (total) / 1 (free) x PCIe 2.0 x8 - full-height (x4 mode) , 1 (total) / 1 (free) x PCI
- 9 x USB 2.0 , 1 x VGA , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x management (NIC)
- FCC Class A certified, TUV GS, C-Tick, BSMI, CB, RoHS, WEEE, cULus, cCSAus, VCCI Class A, JIS C 61000-3-2
- Power supply
- Voltage Required
- Power Provided
- 800 Watt
- 80 PLUS Certification
- 80 PLUS Gold
- Efficiency
- 90%
- 17.7 cm
- 65.1 cm
- 45.6 cm
- 10 °C
- 35 °C
- 10 - 85% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.86 |
