Fujitsu Reliabilty Promise!
At Fujitsu we develop our products to meet the highest standards in both quality and technology. We are so sure of the excellence of our servers that we have created our reliability promise should a hardware defect covered by the Fujitsu standard warranty for your TX1310 M1 (VFY:T1311SX070GB) server occur within one year of purchase we are offering our customers a repair and a full refund of the purchase price.
In order to take advantage of the Reliability Promise refund, you need to register your server within 28 days of purchase (the date shown on your invoice). Simply fill out the registration form Here once you have taken delivery of your server.
The Fujitsu PRIMERGY TX1310 M1 is the ideal first server for small and medium-sized businesses.
With plenty of RAM and Intel® Xeon® processor support it offers more than enough performance for all classic server tasks, such as file, print, web or office applications.
The small tower server is build for reliable 24/7 operation and guarantees data safety by high-end features like ECC memory and an onboard RAID controller. Thanks to the screwless chassis and Fujitsu's Easy Rails for hard disks the server is easy to service. Moreover, the PRIMERGY TX1310 M1 is incredibly silent making it an excellent choice for any office environment
FUJITSU Server PRIMERGY systems provide the most powerful and flexible data center solutions for companies of all sizes, across all industries and for any type of workload. This includes expandable PRIMERGY tower servers for remote and branch offices, versatile rack-mount servers, compact and scalable blade systems, as well as density-optimized scale-out servers.
They convince by business proven quality with a wide range of innovations, highest efficiency cutting operational cost and complexity, and provide more agility in daily operations in order to turn IT faster into a business advantage.
Perfect for small and medium businesses as well as branch offices, FUJITSU Server PRIMERGY TX tower systems are robust and cost-efficient servers by providing rock solid reliability. Additionally they are characterized by simple IT operations, low power consumption and quiet operation so that they can be handled by non-technically trained staff and can be used in standard office environments. By the way: Almost all PRIMERGY TX servers can be rack-mounted to offer best flexibility.
- Fujitsu PRIMERGY TX1310 M1 - tower - Xeon E3-1226V3 3.3 GHz - 8 GB - HDD 2 x 500 GB
- Server - tower
- Localisation
- Region: India, Asia Pacific, EMEA
- Server Scalability
- 1-way
- Processor
- 1 x Intel Xeon E3-1226V3 / 3.3 GHz (, up to 3.7 GHz, (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 8 MB L3 Cache
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s); SATA
- Hard Drive
- 2 x HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- Intel HD Graphics P4600
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Software Included
- ServerView
- 17.5 cm x 41.9 cm x 39.5 cm
- 14 kg
- Limited warranty - 1 year - on-site
- Server
- Product Form Factor
- Tower
- 1-way
- Internal Bays Qty
- 4
- Front Accessible Bays Qty
- 2
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E3-1226V3
- Clock Speed
- 3.3 GHz
- Max Turbo Speed
- 3.7 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel C226
Cache Memory
- Installed Size
- L3 Cache - 8 MB
- 8 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR3 SDRAM - ECC
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered, dual rank
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD
- Capacity
- 2 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
- ECO
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 4
- RAID Level
- RAID 0, RAID 1, RAID 10
Storage Controller (2nd)
- 1 x SATA
- Channel Qty
- 2
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- Intel I217, I210
- Data Link Protocol
- PXE support, Teaming support
- Bays
- 4 (total) / 3 (free) x internal 3.5" x 1/3H , 2 (total) / 1 (free) x external 5.25"
- Slots
- 1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x memory , 2 (total) / 2 (free) x PCIe 3.0 x8 , 1 (total) / 1 (free) x PCIe 2.0 x4 (x1 mode) , 1 (total) / 1 (free) x PCIe 2.0 x8 (x4 mode)
- 4 x USB 2.0 (4 rear) , 5 x USB 3.0 (2 front, 2 rear, 1 internal) , 1 x VGA , 1 x serial , 2 x LAN (Gigabit Ethernet) - RJ-45
- FCC Class A certified, CSA, VCCI, C-Tick, GS, CB, ULC, RoHS, WEEE, KC, ETSI 300 019
- Power supply
- Voltage Required
- Power Provided
- 209 Watt
- 80 PLUS Certification
- 80 PLUS Gold
- Efficiency
- 90%
Operating System / Software
- Software
- ServerView
- 17.5 cm
- 41.9 cm
- 39.5 cm
- 14 kg
- 10 °C
- 35 °C
- Sound Emission
- 24 dBA
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.86 |
