Fujitsu Primergy TX120 S3 SFF XEON E3-1230 2x4 GB Tower Server
Quicklinx: 835NWS00 Mfr#: VFY:T1203SC040IN
  • Xeon
It is the perfect server for environments where space, high server functionality and low TCO are crucial. The unique combination of ultra-compact form factor, low TCO and high availability features, make the PRIMERGY TX120 S3p ideal for demanding environments where space is scarce.
  • Ideal for office, retail and smaller environments
    Its ultra-compact form factor, means that the PRIMERGY TX120 S3p fits everywhere, in either tower or desktop position.
  • High performance and energy efficiency
    Highly efficient power supply unit with 0 W functionality.
  • High manageability and serviceability - saving you time
    The onboard remote management controller makes it easier to service your TX120 S3p.
Fujitsu PRIMERGY TX120 S3p - tower - Xeon E3-1230V2 3.3 GHz - 8 GB - no HDD
Server - tower
Server Scalability
1-way
1 x Intel Xeon E3-1230V2 / 3.3 GHz (3.7 GHz) (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
8 MB L3 Cache
Cache Per Processor
8 MB
RAM
8 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC - PC3-12800
Storage Controller
SATA (SATA 3Gb/s)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
DVD SuperMulti
GigE
Software Included
ServerView, Operations Manager
9.8 cm x 39.9 cm x 34 cm
10 kg
Limited warranty - 1 year - on-site
Server
Product Form Factor
Tower
Server Scalability
1-way
Front Accessible Bays Qty
2
Hot-Swap Bays Qty
4
Processor / Chipset
CPU
Clock Speed
3.3 GHz
Max Turbo Speed
3.7 GHz
Number of Cores
Quad-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Cache Memory
Installed Size
L3 Cache - 8 MB
Cache Per Processor
8 MB
RAM
Installed Size
8 GB / 32 GB (max)
DDR3 SDRAM - ECC
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
Unbuffered, dual channel memory architecture
Configuration Features
2 x 4 GB
Hard Drive
No HDD
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 3Gb/s
Channel Qty
4
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD)
CD / DVD Rewrite Speed
16x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel 82574L, Intel 82579LM
Remote Management Protocol
IPMI 2.0
Remote Management Controller
Integrated Remote Management Controller (iRMC S3)
Wake on LAN (WoL), PXE support
Bays
4 (total) / 4 (free) x hot-swap 2.5" , 1 (total) / 1 (free) x external 3.5" x 1/2H , 1 (total) / 0 (free) x external 5.25" x 1/6H (Slim Line)
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 2 (free) x memory , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x4 - low-profile (x1 mode) , 1 (total) / 1 (free) x PCIe 2.0 x8 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCI - low-profile
8 x USB 2.0 (2 front, 6 rear) , 1 x VGA , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x management (NIC)
No power cord is included
FCC Class A certified, CSA, CB, RoHS, WEEE, cULus
Power supply
Power Provided
250 Watt
Operating System / Software
Software
9.8 cm
39.9 cm
34 cm
10 kg
10 °C
35 °C
10 - 85% (non-condensing)
Sound Emission
22 dBA
