Fujitsu Primergy RX300 Xeon 6C E5645 3x2GB
Quicklinx: 7SP2WS00 Mfr#: VFY:R3006SC200IN
  • Xeon
The PRIMERGY RX300 S6 is a 2U rack server which has been optimized for virtualization purposes. It provides high, scalable I/O performance, extensive memory options, support for major hypervisor products and top performance with latest CPU technology. More precisely: 7xPCIe Gen2 prevent I/O bottlenecks, up to 192 GB of memory allow for optimal sizing of virtual environments and Intel Xeon series CPUs deliver best-in class performance. With its Cool-safe design elements like optimized cooling of the system and highly efficient power supplies the PRIMERGY RX300 S6 is the right system to face Green IT challenges. This 2U powerhouse is also an excellent choice for business-critical processes or heavy-duty applications such as databases.
Fujitsu PRIMERGY RX300 S6 - rack-mountable Xeon E5645 2.4 GHz - 6 GB - no HDD
Server - rack-mountable
Height (Rack Units)
2U
Server Scalability
2-way
1 x Intel Xeon E5645 / 2.4 GHz (, up to 2.67 GHz, (6-core)
Processor Socket
LGA1366 Socket
Cache Memory
12 MB L3 Cache
Cache Per Processor
12 MB
RAM
6 GB (installed) / 192 GB (max) - DDR3 SDRAM - Advanced ECC - PC3-10600
Storage Controller
RAID (SAS 6Gb/s) - PCIe x4 (LSISAS2108); SATA
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
1GbE
Power Redundancy
Optional
Software Included
ServerView
Windows Server Certified
This server is tested, tuned and certified for Windows Server 2008 R2 with OEM-branded hardware. Purchase a Reseller Option Kit to have your server solution pre-loaded.
48.3 cm x 77 cm x 8.6 cm
25 kg
Server
Product Form Factor
Rack-mountable - 2U
Server Scalability
2-way
Front Accessible Bays Qty
2
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Intel Xeon E5645
Clock Speed
2.4 GHz
Max Turbo Speed
2.67 GHz
Number of Cores
6-core
64-bit Computing
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
LGA1366 Socket
Chipset Type
Intel 5520
Cache Memory
Installed Size
L3 Cache - 12 MB
Cache Per Processor
12 MB
RAM
Installed Size
Effective Memory Speed
1333 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
Registered, hot-swappable, Memory Mirroring, triple channel memory architecture
Configuration Features
3 x 2 GB
Hard Drive
No HDD
Storage Controller
1 x RAID - plug-in card - PCIe x4
Controller Interface Type
SAS 6Gb/s
Storage Controller Name
LSISAS2108
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Buffer Size
512 MB
Storage Controller (2nd)
1 x SATA - integrated
Channel Qty
2
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Interfaces
VGA
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel 82575EB
Remote Management Protocol
IPMI 2.0
Remote Management Controller
Integrated Remote Management Controller (iRMC S2)
Bays
1 (total) / 1 (free) x external 5.25" x 1/6H (Slim Line) , 8 (total) / 8 (free) x hot-swap 2.5" , 1 (total) / 1 (free) x external 3.5" x 1/2H
Slots
2 (total) / 1 (free) x CPU , 18 (total) / 15 (free) x memory , 2 (total) / 2 (free) x PCIe 2.0 x8 - low-profile , 5 PCIe 2.0 x8 - low-profile (x4 mode (dual x8 mode if neighbour slot is empty))
2 x serial , 1 x VGA , 8 x USB 2.0 (3 front, 4 rear, 1 internal) , 2 x LAN (Gigabit Ethernet) , 1 x management (NIC)
Rack mounting kit (full extraction), cable arm
FCC Class A certified, CSA, VCCI, C-Tick, GS, CB, CCC, RoHS, WEEE
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
800 Watt
Operating System / Software
Software
ServerView
48.3 cm
77 cm
8.6 cm
25 kg
10 °C
35 °C
10 - 85%
Sound Emission
45 dBA
