The Fujitsu Server PRIMERGY RX200 S8 is a rack server that provides high performance of the Intel Xeon E5 product family, expandability up to 1536 GB of memory and up to 96% energy efficiency - all in 1U space saving housing. Thus, the PRIMERGY RX200 S8 is ideal for virtualization and cloud, small databases as well as for high performance computing.
- Fujitsu PRIMERGY RX200 S8 - rack-mountable Xeon E5-2620V2 2.1 GHz - 8 GB - no HDD
- Server - rack-mountable - redundant fans
- Height (Rack Units)
- 1U
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2620V2 / 2.1 GHz (, up to 2.6 GHz, (6-core)
- Cache Memory
- 15 MB
- Cache Per Processor
- 15 MB
- RAM
- 8 GB (installed) / 1536 GB (max) - DDR3 SDRAM - Advanced ECC
- Storage Controller
- SATA (SATA 3Gb/s); SATA
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- DVD SuperMulti
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- 48.2 cm x 76.2 cm x 4.3 cm
- Limited warranty - 3 years - on-site
- Server
- Product Form Factor
- Rack-mountable - 1U
- 2-way
- Front Accessible Bays Qty
- 1
- Hot-Swap Bays Qty
- 4
Processor / Chipset
- CPU
- Intel Xeon E5-2620V2
- Clock Speed
- 2.1 GHz
- Max Turbo Speed
- 2.6 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel C600
Cache Memory
- Installed Size
- 15 MB
- 15 MB
RAM
- Installed Size
- Technology
- Registered, Memory Mirroring
- Configuration Features
- 1 x 8 GB
Hard Drive
- No HDD
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 3Gb/s
- Channel Qty
- 4
- RAID Level
- RAID 0, RAID 1, RAID 10
Storage Controller (2nd)
- Channel Qty
- 1
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Video Interfaces
- VGA
- Integrated
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- Intel I350
- Data Link Protocol
- Remote Management Protocol
- IPMI 2.0
- Remote Management Controller
- Integrated Remote Management Controller (iRMC S3)
- PXE support
- Bays
- 4 (total) / 4 (free) x hot-swap 2.5" , 1 (total) / 0 (free) x external 5.25" x 1/6H (Slim Line)
- Slots
- 2 (total) / 1 (free) x CPU , 24 (total) / 23 (free) x memory , 3 (total) / 3 (free) x PCIe 3.0 x8 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile
- 6 x USB 2.0 (2 front, 3 rear) , 1 x VGA , 2 x LAN (Gigabit Ethernet) , 1 x management (NIC)
- Redundant fans
- FCC Class A certified, GS, CB, ICES-003 Class A, RoHS, WEEE, cULus, cCSAus, VCCI Class A
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 450 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
- Efficiency
- 94%
- 48.2 cm
- 76.2 cm
- 4.3 cm
- 5 °C
- 40 °C
- 10 - 85% (non-condensing)
- Sound Emission
- 34 dBA
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.17 |
