Fujitsu Primergy RX100 Intel Xeon E3-1220v3 8GB 2x1TB
Quicklinx: 9B0VWS00 Mfr#: VFY:R1008SX010GB
  • Xeon
The Fujitsu PRIMERGY RX100 S8 is an entry mono socket rack server designed to meet small budgets by delivering high energy efficiency. Optimized for infrastructure and communication applications, this 1U server delivers 3 PCIe slots.
Fujitsu PRIMERGY RX100 S8 - rack-mountable Xeon E3-1220V3 3.1 GHz - 8 GB - HDD 2 x 1 TB
Server - rack-mountable - redundant fans
Height (Rack Units)
1U
Server Scalability
1-way
1 x Intel Xeon E3-1220V3 / 3.1 GHz (, up to 3.5 GHz, (Quad-Core)
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
8 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC - PC3-12800
Storage Controller
SATA (SATA 3Gb/s)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
2 x HDD 1 TB (hot-swap) - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
1GbE
Power Redundancy
Optional
48.26 cm x 57.2 cm x 4.28 cm
Limited warranty - 1 year - on-site
Server
Product Form Factor
Rack-mountable - 1U
Server Scalability
1-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
4
Processor / Chipset
CPU
Clock Speed
3.1 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel C226
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
DDR3 SDRAM - ECC
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
Unbuffered, dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
HDD - hot-swap
2 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Business critical
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 3Gb/s
Channel Qty
5
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Video Interfaces
VGA
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel I210
Remote Management Protocol
IPMI 2.0
Remote Management Controller
Integrated Remote Management Controller (iRMC S3)
Wake on LAN (WoL), PXE support
Bays
4 (total) / 2 (free) x hot-swap 3.5" , 1 (total) / 0 (free) x external 5.25" x 1/6H (Slim Line)
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x memory , 2 (total) / 2 (free) x PCIe 3.0 x8 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x8 - low-profile (x4 mode)
4 x USB 2.0 , 4 x USB 3.0 (2 front, 2 rear) , 1 x VGA , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x management (NIC)
Redundant fans
FCC Class A certified, VCCI, GOST, GS, CB, RoHS, WEEE, cULus, KC, cCSAus
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
450 Watt
Efficiency
94%
48.26 cm
57.2 cm
4.28 cm
5 °C
10 - 85% (non-condensing)
