The FUJITSU Server PRIMERGY RX2540 M2 is the 2U dual socket rack server for high usability, scalability and cost-efficiency. Its Intel Xeon processors in conjunction with DDR4 memory technology with up to 1.5 TB increases performance to meet the requirements for data center processing, enterprise applications as well as collaboration. The modular design offers excellent expandability of up to 24 disk drives, up to 8 PCIe Gen3 expansion cards, and best-in-class energy efficiency thanks to two hot-plug power supplies with up to 96% efficiency meet the future demands of data growth. To complete the picture, DynamicLoM makes network connections more flexible and ready for future modifications. Operation in higher ambient temperatures is ensured by the Cool-safe Advanced Thermal Design resulting in lower OPEX.
- Fujitsu PRIMERGY RX2540 M2 - rack-mountable Xeon E5-2620V4 2.1 GHz - 16 GB - no HDD
- Server - rack-mountable
- Height (Rack Units)
- 2U
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2620V4 / 2.1 GHz (up to 3 GHz, (8-core)
- Processor Socket
- LGA2011-v3 Socket
- Cache Memory
- 20 MB
- Cache Per Processor
- 20 MB
- RAM
- 16 GB (installed) / 1536 GB (max) - DDR4 SDRAM - Advanced ECC - PC4-19200
- Storage Controller
- RAID (SATA 6Gb/s / SAS 12Gb/s) (LSISAS3108); SATA (SATA 6Gb/s)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- Software Included
- ServerView
- 48.24 cm x 77 cm x 8.66 cm
- Limited warranty - 3 years - on-site
- Server
- Product Form Factor
- Rack-mountable - 2U
- 2-way
- Front Accessible Bays Qty
- 2
- Hot-Swap Bays Qty
- 16
Processor / Chipset
- CPU
- Intel Xeon E5-2620V4
- Clock Speed
- 2.1 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA2011-v3 Socket
- Chipset Type
- Intel C612
- Front Side Bus
- 2133 MHz
Cache Memory
- Installed Size
- 20 MB
- 20 MB
RAM
- Installed Size
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Memory Specification Compliance
- PC4-19200
- Form Factor
- DIMM 288-pin
- Slots
- 24 (Total) / 23 (empty)
- Registered, Memory Mirroring, Memory Sparing
- Configuration Features
- 1 x 16 GB
Hard Drive
- No HDD
Storage Controller
- 1 x RAID
- Controller Interface Type
- SATA 6Gb/s / SAS 12Gb/s
- Storage Controller Name
- LSISAS3108
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
- Buffer Size
- 2 GB
Storage Controller (2nd)
- 1 x SATA
- SATA 6Gb/s
- Channel Qty
- 1
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Video Interfaces
- VGA
- Interface (Bus) Type
- PCI Express 2.1
- Ethernet Ports
- 4 x Gigabit Ethernet
- Data Link Protocol
- Remote Management Protocol
- IPMI 2.0
- Remote Management Controller
- Integrated Remote Management Controller (iRMC S4)
- PXE support
- Bays
- 16 (total) / 16 (free) x hot-swap 2.5" , 2 (total) / 2 (free) x external 5.25"
- Slots
- 2 (total) / 1 (free) x CPU , 24 (total) / 23 (free) x DIMM 288-pin , 3 (total) / 3 (free) x PCIe 3.0 x8 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x8 - low-profile (2 processors must be installed) , 3 (total) / 3 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile (2 processors must be installed)
- 5 x USB 2.0 , 5 x USB 3.0 (2 front, 2 rear, 1 internal) , 2 x VGA , 1 x management - RJ-45 , 4 x LAN (Gigabit Ethernet) - RJ-45
- Included Accessories
- Rack mounting kit
- FCC Class A certified, C-Tick, BSMI, GS, CB, CCC, RoHS, WEEE, KC, VCCI V-3 Class A ITE, cCSAus, JIS C 61000-3-2
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 800 watt
- 80 PLUS Certification
- 80 PLUS Platinum
- Efficiency
- 94%
Operating System / Software
- Software
- ServerView
- 48.24 cm
- 77 cm
- 8.66 cm
- 5 °C
- 45 °C
- 10 - 85% (non-condensing)
- Sound Emission
- 44 dBA
