Fujitsu Primergy Intel Xeon E31220v6 8GB LFF Tower Server
Quicklinx: CYGPWS00 Mfr#: VFY:T1333SC020IN
  • Xeon
The FUJITSU Server PRIMERGY TX1330 M3 is a highly expandable mono-socket server for Small and Medium Enterprises which need application oriented performance coupled with high storage expandability, and growth potential via a comprehensive range of options. It features the latest Intel Xeon product family processor, plus up to 64 GB RAM for managing application oriented performance for today and tomorrow. The server is designed for scalability and workload versatility with features such as up to twenty-four 2.5-inch drives, data backup options, and 4x PCIe slots coupled with compatible RAID and networking options. Reliability is enhanced with the Fujitsu Battery Backup unit, and high-efficiency (94%) redundant power supplies. Comprehensive server management plus silent operation ease both administration and deployment, making the platform ideal for SME environments.
Fujitsu PRIMERGY TX1330 M3 - tower Xeon E3-1220V6 3 GHz - 8 GB - no HDD
Server - tower
Height (Rack Units)
4U
Region: India, Asia Pacific, EMEA
Server Scalability
1-way
1 x Intel Xeon E3-1220V6 / 3 GHz (up to 3.5 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM - ECC
Storage Controller
SATA (SATA 6Gb/s)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
DVD SuperMulti
1GbE, iSCSI
OS Provided
No operating system
Software Included
ServerView
17.7 cm x 56 cm x 45.5 cm
15 kg
Limited warranty - parts and labour - 1 year - on-site
Server
Product Form Factor
Tower - 4U
Server Scalability
1-way
Front Accessible Bays Qty
3
Hot-Swap Bays Qty
4
Processor / Chipset
CPU
Clock Speed
3 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel C236
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
DDR4 SDRAM - ECC
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
Slots
4 (Total) / 3 (empty)
Unbuffered, dual channel memory architecture, single rank
Configuration Features
1 x 8 GB
Hard Drive
No HDD
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
4
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Video Interfaces
VGA
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel I210
Ethernet, Fast Ethernet, Gigabit Ethernet, iSCSI
Remote Management Protocol
IPMI 2.0
Remote Management Controller
Integrated Remote Management Controller (iRMC S4)
Wake on LAN (WoL), PXE support
Bays
4 (total) / 4 (free) x hot-swap 3.5" , 3 (total) / 2 (free) x external 5.25"
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x memory , 1 (total) / 1 (free) x PCIe 3.0 x4 - full-height (x1 mode) , 1 (total) / 1 (free) x PCIe 3.0 x4 - full-height , 2 (total) / 2 (free) x PCIe 3.0 x8 - full-height
5 x USB 2.0 (4 rear, 1 internal) , 5 x USB 3.0 (2 front, 2 rear, 1 internal) , 1 x VGA , 1 x serial , 2 x LAN (Gigabit Ethernet) - RJ-45 , 1 x management - RJ-45
Power supply dummy
No power cord is included
FCC Class A certified, VCCI, C-Tick, BSMI, GS, CB, CCC, RoHS, WEEE, cULus, GOST-R, KC, cCSAus, JIS C 61000-3-2
Power supply - hot-plug
Power Provided
450 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
94%
Operating System / Software
OS Provided
No operating system
Software
ServerView
17.7 cm
56 cm
45.5 cm
15 kg
10 °C
35 °C
10 - 85% (non-condensing)
