Fujitsu P24W-7 24" 1920x1200 5ms VGA DVI-D HDMI DisplayPort USB LED Monitor
Quicklinx: 9NKTWS00 Mfr#: BDL:K1498V140-UK
If you're a pixel, color and performance-hungry professional using demanding applications, the Fujitsu P24W-7 LED Display is the perfect choice. The display provides outstanding picture performance thanks to a cutting-edge graphic panel. It also boasts unique and innovative features such as the patent-applied Presence Sensor technology and the Always Available Powered USB Hub.
  • Pure performance
    Due to wide viewing angle panel technology Fujitsu P Line displays deliver the best viewing experience always. They're a delight for your eyes with razor-sharp pictures up to 3.7 million pixels.
  • 0-Watt power in power save mode
    The innovative 0-Watt power save mode stops energy waste in power save mode. When the PC signalizes off-mode, a switching display element cuts the monitor completely from the power line. An absolutely unique energy saving solution!
  • ABC - automatic brightness control
    A light sensor on the top of the display measures the ambient light and adjusts the brightness accordingly. ABC optimizes ergonomic conditions and saves energy.
  • Exceeding ergonomics
    With focus on ergonomics you prefer a stand, totally flexible for individual adjustments. Best-in-class height-adjust, stunning swivel, tilt and rotation and automatic switch to portrait screen guarantee a healthy, fatigue-free posture during long usage sessions.
Fujitsu P24W-7 LED - LED monitor - 24"
LED-backlit LCD monitor - 24"
Presence sensor, USB 3.0 hub
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
100% sRGB, 77% NTSC (CIE 1931)
Input Connectors
2xHDMI, DVI-D, VGA, DisplayPort
Speakers
Internal
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
Marble grey
55.9 cm x 20.4 cm x 38.4 cm
7.1 kg
Environmental Standards
TCO Certified Displays 7, TCO Certified Displays 8, ENERGY STAR Qualified
FCC Class B certified, TUV GS, VCCI, cUL, EN 60950, SASO, TUV S, RoHS, ISO 9241-307, WEEE, Directive 2004/108/EEC, EAC, VESA MIS-D 100 C
Display Type
Diagonal Size
24"
Built-in Devices
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
48 - 76 Hz
Horizontal Refresh Rate
30 - 82 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
9300K, 6500K, 7500K
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, clock, black level
OSD Languages
Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
sRGB colour management, HDCP, Auto Brightness Control, ECO button, DisplayView, DICOM calibrated, WideView
Marble grey
55.9 cm x 20.4 cm x 38.4 cm - with stand
7.1 kg
Audio
Speakers - stereo - internal
Output Power / Channel
1.5 Watt
DisplayPort , HDMI , DVI-D (HDCP) , VGA , Audio line-in , Audio line-out , 4 x USB 3.0 downstream , MHL / HDMI , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+35
Swivel Angle
340
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 0-Watt technology
1 x VGA cable - 1.8 m , 1 x DVI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x USB cable - USB Type A to B - 1.8 m
MTBF
70,000 hour(s)
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 55.9 cm - depth: 20.4 cm - height: 38.4 cm - weight: 7.1 kg , Without stand - width: 55.9 cm - depth: 6.4 cm - height: 36.6 cm - weight: 4.2 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
5 °C
35 °C
