If you're a pixel, color and performance-hungry professional using demanding applications, the Fujitsu P24W-7 LED Display is the perfect choice. The display provides outstanding picture performance thanks to a cutting-edge graphic panel. It also boasts unique and innovative features such as the patent-applied Presence Sensor technology and the Always Available Powered USB Hub.
Pure performance
Due to wide viewing angle panel technology Fujitsu P Line displays deliver the best viewing experience always. They're a delight for your eyes with razor-sharp pictures up to 3.7 million pixels. -
0-Watt power in power save mode
The innovative 0-Watt power save mode stops energy waste in power save mode. When the PC signalizes off-mode, a switching display element cuts the monitor completely from the power line. An absolutely unique energy saving solution! -
ABC - automatic brightness control
A light sensor on the top of the display measures the ambient light and adjusts the brightness accordingly. ABC optimizes ergonomic conditions and saves energy. -
Exceeding ergonomics
With focus on ergonomics you prefer a stand, totally flexible for individual adjustments. Best-in-class height-adjust, stunning swivel, tilt and rotation and automatic switch to portrait screen guarantee a healthy, fatigue-free posture during long usage sessions.
- Fujitsu P24W-7 LED - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Presence sensor, USB 3.0 hub
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 100% sRGB, 77% NTSC (CIE 1931)
- Input Connectors
- 2xHDMI, DVI-D, VGA, DisplayPort
- Speakers
- Internal
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Marble grey
- 55.9 cm x 20.4 cm x 38.4 cm
- 7.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, TUV GS, VCCI, cUL, EN 60950, SASO, TUV S, RoHS, ISO 9241-307, WEEE, Directive 2004/108/EEC, EAC, VESA MIS-D 100 C
- Display Type
- Diagonal Size
- 24"
- Built-in Devices
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 48 - 76 Hz
- Horizontal Refresh Rate
- 30 - 82 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 9300K, 6500K, 7500K
- Controls & Adjustments
- Mute, volume, brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, clock, black level
- OSD Languages
- Danish, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese
- sRGB colour management, HDCP, Auto Brightness Control, ECO button, DisplayView, DICOM calibrated, WideView
- Marble grey
- 55.9 cm x 20.4 cm x 38.4 cm - with stand
- 7.1 kg
Audio
- Speakers - stereo - internal
- Output Power / Channel
- 1.5 Watt
- DisplayPort , HDMI , DVI-D (HDCP) , VGA , Audio line-in , Audio line-out , 4 x USB 3.0 downstream , MHL / HDMI , USB 3.0 upstream
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 340
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), 0-Watt technology
- Cables Included
- 1 x VGA cable - 1.8 m , 1 x DVI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x USB cable - USB Type A to B - 1.8 m
- MTBF
- 70,000 hour(s)
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- Included Software
- Drivers & Utilities
- Dimensions & Weight Details
- With stand - width: 55.9 cm - depth: 20.4 cm - height: 38.4 cm - weight: 7.1 kg , Without stand - width: 55.9 cm - depth: 6.4 cm - height: 36.6 cm - weight: 4.2 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
