Fujitsu N7100 Network Document Scanner
Quicklinx: C38WWS00 Mfr#: PA03706-B001
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 216 x 355.6 mm
Interface: Gigabit LAN
Compatibility: PC, Unix
£940.30 ex VAT
£1,128.36 inc VAT
With the functionality of many devices, yet the simplicity of one, the N7100 network scanner contains the qualities organizations of all sizes desire to improve business processes.
A large size screen with integrated on-screen keyboard and PC functions are equipped in this compact network scanner. It can be used in the office or a teller window where space is limited. The user can perform scanning, data saving and transmission without the need to operate from a computer.
Scanning speed is consistent at 25 pages per minute (ppm) even when scanning full A4 color, double-sided, at 300dpi. N7100 is equipped with accurate and stable feeding mechanisms that support scanning from thin paper to thick paper, and plastic cards. Plastic ID cards and application forms can be scanned together easily at a teller window of banks or hospitals.
In order for the user not to feel any stress, the image processing after scanning is quick thanks to the enhanced CPU/memory. The time from the start of scanning to the finish including image processing (when the preview of the last scanned page appears) is 50% shorter than the previous model. For regular scanning routines, only one touch of the scan button is necessary which greatly improves the productivity.
The N7100 achieves high security on the premise that it is shared by multiple users. Not only verification before scanning, but also the encryption for paused scans and data deletion after scanning are performed automatically. Users can use the network scanner with peace of mind.
Administrators can customize the touch panel job menu and scan settings of N7100 to suit the work of a specific user or user group registered to the scanner. The user's application can be integrated to the scanner as add-in software using the exclusive SDK (for Windows). N7100 comes with an open USB port to connect a keyboard or other USB devices (except USB memory). N7100 can be customized to be a terminal exclusively for your operation.
The scanner driver PaperStream IP which supports TWAIN saves the hassle in fine adjusting the document for OCR processes. It automatically converts the images into exceptionally clean images, accelerating OCR even when scanning wrinkled/soiled document or documents with a background.
Advanced automated functions ensure N7100 digitizes your documents with remarkable precision and efficiency. Produce beautiful scans quickly with barely the need to lift a finger.
Fujitsu Network Scanner N7100 - document scanner - desktop - Gigabit LAN
Document scanner - desktop
Interface Type
Gigabit LAN
Scan Element Type
Dual CIS
Light Source
RGB LED array
Additional Functions
Email, fax, scan to print, scan to network share, scan to FTP
Max Supported Document Size
216 x 355.6 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
25 ppm (mono) / 25 ppm (colour)
Max Document Size
216 mm x 355.6 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card, envelope, post card
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
400 scans per day
AC 120/230 V
30 cm x 23.2 cm x 17.2 cm
6 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
Gigabit LAN
216 x 355.6 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
Dual CIS
Bulb / Light Source Type
RGB LED array
Max Document Scan Speed B/W
25 ppm
Max Document Scan Speed Colour
25 ppm
Duty Cycle
400 scans per day
Scanner Speed Details
25 ppm - portrait - A4 - 200 dpi , 25 ppm - portrait - A4 - 300 dpi , 50 ipm - portrait - A4 - 200 dpi , 50 ipm - portrait - A4 - 300 dpi
Scanner Features
8.4" touch screen TFT display, automatic page size detection, Ultrasonic Multi Feed Detection
Media Handling
Max Document Size
216 mm x 355.6 mm
Supported Document Size Details
Long document - up to 216 x 3048 mm
Automatic
50 sheets
Gigabit LAN
RoHS 2011/65/EU
ENERGY STAR Certified
AC 120/230 V
Power Consumption Operational (Standby)
38 Watt
Power Consumption Stand by
1 Watt
Power Consumption Sleep
2 Watt
30 cm
23.2 cm
17.2 cm
6 kg
5 °C
35 °C
20 - 80% (non-condensing)
C38W Fujitsu 5x Carrier Sheets for ScanSnap In Stock £34.31
C38W C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
C38W C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.22
C38W C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.95
C38W C2G 2m Cat6a Shielded Patch - Blue In Stock £7.33
C38W Fujitsu Extends Warranty From 1 Year to 3 Year For Network - Inc Replacement and Shipping In Stock £240.21
C38W Fujitsu Extends Warranty to 3 Year for Network Scanners - 8hrs On-Site 8hrs Fix In Stock £453.56
Compatibility: PC
Compatibility: Unix
Brand: Fujitsu
Price Range Ex VAT: 750 - 1000
