PC mouse M440 ECO is an essential input device, made from 100% bio material with PVC free cable. Following all hand movements smoothly and precisely, the elegant M440 ECO works on nearly every surface. It features two buttons and one scroll wheel button. The human-centric shape makes it comfortable for both right and left-handed users. M440 ECO is equipped with the convenient USB Plug and Play.
- Fujitsu M440 ECO - mouse - USB - black
- Mouse
- Connectivity Technology
- Wired - USB
- Black
- Orientation
- Right and left-handed
- 6.1 cm x 10.9 cm x 3.6 cm
- 102 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 1000 dpi
- Scrolling wheel
- Cables Included
- 1 x USB cable - 1.8 m
- OS Required
- Microsoft Windows Vista / XP / 7
- Package Type
- OEM
- 2-year warranty
- Designed For
- Celsius C780, H7510, J5010, J550, J580, M7010, M770, R970, W5010, W570, W580; CELSIUS Mobile H970; ESPRIMO D538/E94, D556, D7010, D7011, D738/E94, D757, D757/E94, D9010, D9011, D956, D957, D957/E94, D958, D958/E94, G9010, K5010/24, P556, P558, P956/E94, P957, P9910, Q520, Q7010, Q956, Q958, X956
- Mouse
- Orientation
- 6.1 cm
- 10.9 cm
- 3.6 cm
- 102 g
- Black
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 3
- 1000 dpi
- Scrolling wheel
- 1 x USB - 4 pin USB Type A
- Cables Included
- Plug and Play, FCC Class B certified, VCCI, SASO, ICES-003 Class B, RoHS, WEEE
- Package Type
- OEM
- OS Required
- Limited warranty - 2 years
- Designed For
- Fujitsu Celsius C780, C780power, H7510, J5010, J550, J550/2, J550/2-L, J580, M7010, M7010power, M7010X, M7010Xpower, M770, M770power, M770powerx, M770x, R940 POWER, R970, R970B, R970Bpower, R970power, W5010, W570power, W580, W580power, W580power+ , Fujitsu CELSIUS Mobile H970 , Fujitsu ESPRIMO C910-L, D538/E94+, D556/2/E85+, D556/2/E90+, D556/E85+, D556/E90+, D556/PX, D7010/8, D7011, D738/E94+, D757/E85+, D757/E90+, D757/E94+, D9010, D9011, D956/M (International Energy Star Program), D957/E85+, D957/E90+, D957/E94+, D958/E85+, D958/E94+, G9010, K5010/24, P556 E85+, P556 E90+, P556/2/E85+, P558, P756 E85+, P756 E90+, P756 E94+, P956 E90+, P956/E94+, P957/power, P9910, Q520/K, Q7010, Q956/MRE, Q958/MRE, X956/T , Fujitsu LIFEBOOK E780, E780 proGREEN, P3110, P770, P8110, S710, S710 proGREEN, S760, T730, T900, TH700 , Fujitsu PRIMERGY MX130 S2, RX900 S1, RX900 S2
