Fujitsu Lifebook U745 Intel Core i5 5200U 8GB 256GB 14" Windows 8.1 Professional
Quicklinx: B3H1WS00 Mfr#: VFY:U7450M45CBGB
  • Core i5
  • Windows 8.1 Pro 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
The FUJITSU notebook LIFEBOOK U745 is a slim and light Ultrabook for professionals supporting optimum mobility for business trips and ergonomics in the office. It is with a 35.6 cm (14-inch) anti-glare display with touch panel and backlit keyboard offers you mobile comfort. Moreover, an embedded palm vein sensor option guarantees ultimate protection of your data. The common port replicator with the LIFEBOOK E family facilitates workplace sharing, the VGA port allows you to present on demand.
  • Elegance in combination with ergonomics
    U745 is a slim and lightweight notebook, HD+ anti-glare display with touch panel, magnesium housing with aluminum palm rest.
  • Optimum mobility and workplace convenience in one
    Ultrabook features VGA port, display port, common port replicator with LIFEBOOK E family, Anytime USB Charge to charge phones, media devices, even when the system is turned off, backlit keyboard.
  • Ultimate connectivity
    Ultimate connectivity is provided thanks to pull-out LAN connector, embedded 4G/LTE or 3G/UMTS, WLAN and Bluetooth.
  • Easy upgradeability
    Door serves to exchange the battery, memory and internal storage.
Fujitsu LIFEBOOK U745 - 14" - Intel Core i5 - 5200U - 8 GB RAM - 256 GB SSD - 4G LTE
Ultrabook
Operating System
Win 8.1 Pro 64-bit
Intel Core i5 (5th Gen) - 5200U / 2.2 GHz, up to 2.7 GHz / 3 MB Cache
8 GB DDR3L (1 x 4 GB + 4 GB (soldered))
Storage
256 GB SSD
Display
14" LED backlight touchscreen 1600 x 900 / HD+
Graphics
Intel HD Graphics 5500
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
Wireless Broadband (WWAN)
4G LTE
4-cell - up to 10 hour(s)
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
33.26 cm x 23.4 cm x 1.9 cm
1.7 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 2 years - pick-up and return
Ultrabook
Operating System
Processor / Chipset
CPU
Intel Core i5 (5th Gen) 5200U / 2.2 GHz
Max Turbo Speed
2.7 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 4 GB + 4 GB (soldered))
Max RAM Supported
12 GB
DDR3L SDRAM
Speed
1600 MHz / PC3-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
256 GB SSD 2.5" SATA 6Gb/s
Display
14"
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
1600 x 900 (HD+)
Widescreen
Image Aspect Ratio
16:9
Anti-glare
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Sound
Stereo speakers, stereo microphone
Codec
Realtek ALC3233
Input
Keyboard, touchpad
Keyboard Backlight
ECO button, status led
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7265
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I218-LM
2x UMTS/LTE aerials
Generation
4G
LTE
Controller
Sierra Wireless AirPrime EM7305
Max Transfer Rate
100 Mbps
4-cell lithium polymer
45 Wh
Run Time
Up to 10 hour(s)
AC Adapter
Input
Output
19 V
Connections & Expansion
3 x USB 3.0 , VGA , DisplayPort , LAN , Headphone output , Microphone input , Dock
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Adobe Acrobat Reader, LifeBook Application Panel, Fujitsu Shock Sensor Utility, Fujitsu Display Manager, Power Saving Utility, Plugfree Network, Microsoft Office 2013 (Trial), DeskView Client, DeskView Instant BIOS Management, DeskView Integration for Symantec Management Platform, McAfee Multi Access (60 days trial), Workplace Protect, Windows 8.1 Pro 64-bit recovery DVD
Dockable
Security
Administrator password, system password, hard drive password, wake on LAN, 1 USB 3.0 with Anytime USB Charge
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
WHQL, CB, RoHS, ISO 9241-307, WEEE
1.7 kg
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
20 - 85%
