The FUJITSU Notebook LIFEBOOK U745 is a slim and light Ultrabook for professionals supporting optimum mobility for business trips and ergonomics in the office. Its low weight from 1.55 kg combined with a 35.6 cm (14-inch) anti-glare display with touch panel and backlit keyboard options offers you mobile comfort. The 4G/LTE or 3G/UMTS option and the pull-out LAN connector grant you added connectivity. Moreover, an embedded palm vein sensor option guarantees ultimate protection of your data. The common port replicator with the LIFEBOOK E family facilitates workplace sharing; the VGA port allows you to present on demand.
Elegance in combination with ergonomics
U745 is a slim 19 mm and lightweight notebook from 1.55 kg, HD+ anti-glare display with touch panel option, magnesium housing with aluminum palm rest. -
Optimum mobility and workplace convenience in one
Ultrabook features VGA port, display port, common port replicator with LIFEBOOK E family, Anytime USB Charge to charge phones, media devices even when the system is turned off, backlit keyboard option. -
Premium security
Security options include embedded palm vein sensor or fingerprint sensor option, Advanced Theft Protection, Full Disk Encryption, SmartCard reader option, Trusted Platform Module option. -
Ultimate connectivity
Ultimate connectivity is provided thank to pull-out LAN connector, embedded 4G/LTE or 3G/UMTS option, WLAN and Bluetooth. -
Easy upgradeability
Door serves to exchange the battery, memory and internal storage.
- Fujitsu LIFEBOOK U745 - 14" - Core i3 5010U - vPro - 4 GB RAM - 128 GB SSD
- Product Type
- Ultrabook
- Operating System
- Win 7 Pro 64-bit + Windows 10 Pro 64-bit Licence
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i3 (5th Gen) 5010U / 2.1 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (provided memory is soldered)
- Storage
- 128 GB SSD
- Display
- 14" LED backlight 1600 x 900 / HD+
- Graphics
- Intel HD Graphics 5500
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 4-cell - up to 10 hours
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- 33.26 cm x 23.4 cm x 1.9 cm
- 1.55 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 2 years - pick-up and return
- Product Type
- Ultrabook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition + Windows 10 Pro 64-bit Licence
Processor / Chipset
- CPU
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Smart Cache
- RAM
- 4 GB (provided memory is soldered)
- Max RAM Supported
- 12 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 1
- Empty Slots
- 1
Storage
- Main Storage
- 128 GB SSD SATA 6Gb/s
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1600 x 900 (HD+)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Anti-glare, magnesium lid
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Sound
- Stereo speakers, stereo microphone
- Codec
- Realtek ALC3233
Input
- Keyboard, touchpad
- ECO button, status led
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7265
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM
- Intel Wireless Display (WiDi), Wake-on-LAN (WOL), 2x UMTS/LTE aerials
Wireless Broadband (WWAN)
- Generation
- 3G/4G upgradable
- Technology
- 4-cell lithium polymer
- Capacity
- 45 Wh
- Run Time
- Up to 10 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 19 V
Connections & Expansion
- 3 x USB 3.0 , VGA , DisplayPort , LAN , Headphone output , Microphone input , Dock
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- LifeBook Application Panel, Adobe Reader, Fujitsu Shock Sensor Utility, Computrace, Fujitsu Display Manager, Power Saving Utility, Fujitsu Recovery, Plugfree Network, Microsoft Office 2013 (Trial), DeskView Client, DeskView Instant BIOS Management, DeskView Integration for Symantec Management Platform, McAfee Multi Access (60 days trial), Workplace Protect, Microsoft Push Button Recovery, Fujitsu DeskUpdate, Windows 7 Professional 64-bit / Windows 10 Pro 64-bit Twin-Pack recovery DVD
- Dockable
- Security
- Administrator password, system password, hard drive password, 1 USB 3.0 with Anytime USB Charge, Preboot Execution Environment (PXE) support
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- WHQL, CB, RoHS, ISO 9241-307, WEEE
- 1.55 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 85%
