Fujitsu LIFEBOOK U745 i7-5600U 14" 8GB 256GB SSD Windows 10 Pro
Quicklinx: CWRCWS00 Mfr#: VFY:U7450M27CBGB
  • Core i7
  • Bluetooth 4.0
  • IEEE 802.11n
The FUJITSU notebook LIFEBOOK U745 is a slim and light Ultrabook for professionals supporting optimum mobility for business trips and ergonomics in the office. It is with a 35.6 cm (14-inch) anti-glare display with touch panel and backlit keyboard offers you mobile comfort. Moreover, an embedded palm vein sensor option guarantees ultimate protection of your data. The common port replicator with the LIFEBOOK E family facilitates workplace sharing, the VGA port allows you to present on demand.
  • Elegance in combination with ergonomics
    U745 is a slim and lightweight notebook, HD+ anti-glare display with touch panel, magnesium housing with aluminum palm rest.
  • Optimum mobility and workplace convenience in one
    Ultrabook features VGA port, display port, common port replicator with LIFEBOOK E family, Anytime USB Charge to charge phones, media devices, even when the system is turned off, backlit keyboard.
  • Ultimate connectivity
    Ultimate connectivity is provided thanks to pull-out LAN connector, embedded 4G/LTE or 3G/UMTS, WLAN and Bluetooth.
  • Easy upgradeability
    Door serves to exchange the battery, memory and internal storage.
Fujitsu LIFEBOOK U745 - 14" - Intel Core i7 - 5600U - vPro - 8 GB RAM - 256 GB SSD - 4G LTE
Ultrabook
Operating System
Win 10 Pro 64-bit
Platform Technology
Intel vPro Platform
Intel Core i7 (5th Gen) - 5600U / 2.6 GHz, up to 3.2 GHz / 4 MB Cache
8 GB DDR3L (1 x 4 GB + 4 GB (soldered))
Storage
256 GB SSD - FDE, TCG Opal Encryption
Display
14" LED backlight 1600 x 900 / HD+
Graphics
Intel HD Graphics 5500
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
Wireless Broadband (WWAN)
4G LTE
4-cell - up to 10 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
33.26 cm x 23.4 cm x 1.9 cm
1.55 kg
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Limited warranty - 2 years - pick-up and return
Ultrabook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i7 (5th Gen) 5600U / 2.6 GHz
Max Turbo Speed
3.2 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Platform Technology
Intel vPro Platform
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 4 GB + 4 GB (soldered))
Max RAM Supported
12 GB
DDR3L SDRAM
Speed
1600 MHz / PC3-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
256 GB SSD 2.5" SATA 6Gb/s - Full Disk Encryption (FDE), TCG Opal Encryption
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1600 x 900 (HD+)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Anti-glare, magnesium lid
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Camera Features
LED indicator
Sound
Stereo speakers, two microphones
Codec
Realtek ALC3233
Input
Keyboard, touchpad
Keyboard Backlight
ECO button, status led
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7265
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I218-LM
Remote Management Protocol
DMI, CIM
Intel Wireless Display (WiDi), Wake-on-LAN (WOL), 2x UMTS/LTE aerials
Generation
4G
LTE
Controller
Sierra Wireless AirPrime EM7305
Max Transfer Rate
100 Mbps
4-cell lithium polymer
45 Wh
Run Time
Up to 10 hours
AC Adapter
Input
Output
65 Watt, 19 V, 3.42 A
Connections & Expansion
Slots
1 x SIM card
Interfaces Details
2 x USB 3.0 , USB 3.0 (Anytime USB Charge) , VGA , DisplayPort , Headphone output , Microphone input , LAN , Dock
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
LifeBook Application Panel, Adobe Reader, Microsoft Office (Trial), Fujitsu Shock Sensor Utility, Fujitsu Display Manager, Power Saving Utility, DeskView Client, DeskView Instant BIOS Management, McAfee Multi Access (60 days trial), Workplace Protect, Fujitsu DeskUpdate, LTE/UMTS connection manager, Windows 10 64-bit recovery DVD
Dockable
Security
Administrator password, system password, hard drive password, Intel Active Management Technology (iAMT), BIOS Absolute Persistence, Preboot Execution Environment (PXE) support
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
WHQL, RoHS, ISO 9241-307, WEEE
1.55 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
5 °C
35 °C
20 - 85%
