Its ultra-thin, durable aluminum housing with magnesium lid and its light weight let you to travel in comfort. With a simple flip of the super crisp, rotatable 13.3´ display with pen and touch support you can switch to tablet mode. The backlit keyboard, enterprise-grade security features, pull-out LAN connector and embedded 4G/LTE let you work securely wherever you are.
Tablet and Ultrabook in one
Bidirectional rotatable 13.3" display with dual digitizer allows audit-proof pen and touch input, or with the keyboard. Give your work a personal touch and enjoy the benefits of precise handwriting recognition and multiple-touch. -
Ultimate mobility
Be available anytime anywhere with wireless connectivity and additional features that ease your life. -
Highest security
SmartCard reader, fingerprint sensor, OPAL encrypted drives and Trusted Platform Module (TPM). Protect your company data against unauthorized third-party access. -
Ergonomic working
Super high resolution display and backlit keyboard maximize your productivity with ultimate convenience and comfort features for business users.
- Fujitsu LIFEBOOK T936 - 13.3" - Intel Core i5 - 6200U - 8 GB RAM - 256 GB SSD - 4G LTE
- Product Type
- Ultrabook - convertible
- Operating System
- Win 10 Pro
- Processor
- Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - FDE, TCG Opal Encryption
- Display
- 13.3" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 520
- Input Device
- Digitizer, digital pen
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Wireless Broadband (WWAN)
- 4G LTE
- Battery
- 4-cell - up to 10 hours
- Ambient light sensor
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- 32.1 cm x 23.5 cm x 1.93 cm
- 1.6 kg
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 2 years - pick-up and return - availability: 9 hours a day / Monday-Friday
- Product Type
- Operating System
- Windows 10 Pro
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 256 GB SSD SATA 6Gb/s - Full Disk Encryption (FDE), TCG Opal Encryption
Display
- 13.3"
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 330 cd/m²
- Glossy, glare, WideView, aluminum enclosure, magnesium lid
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1920 x 1080
- Resolution
- 2 Megapixel
- Sound
- Stereo speakers, two microphones
- Codec
- Realtek ALC283
Input
- Keyboard, digitizer, touchpad, digital pen
- Multi-gesture touch pad, pen slot, Dual Digitizer
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM
- Remote Management Protocol
- DMI, CIM
- Wake-on-LAN (WOL), 2x UMTS/LTE aerials
- Generation
- 4G
- Technology
- LTE
- Controller
- Sierra Wireless AirPrime EM7305 - SIM card
- Max Transfer Rate
- 100 Mbps
- Technology
- 4-cell lithium polymer
- Capacity
- 45 Wh
- Run Time
- Up to 10 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19 V, 3.42 A
Connections & Expansion
- Slots
- 1 x SIM card (1 free)
- Interfaces Details
- USB 3.0 , HDMI , LAN , Headphone/microphone combo jack , Dock , USB 3.0 (Anytime USB Charge)
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Adobe Reader, Fujitsu Security Application Panel, Fujitsu Shock Sensor Utility, Fujitsu Display Manager, CyberLink Youcam, McAfee Internet Security Suite (60 days trial), Power Saving Utility, Plugfree Network, SmartAccess, Microsoft Office 2013 (Trial), DeskView Client, DeskView Instant BIOS Management, Fujitsu DeskUpdate, Absolute Computrace Mobile
- Integrated Options
- Dockable
- Security
- Administrator password, system password, hard drive password, digital compass, capacitive touch screen, gyroscope, Windows button, 1 USB 3.0 with Anytime USB Charge, 3D accelerometer, Preboot Execution Environment (PXE) support
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter, active pen
- GOST, EN 60950, RoHS, WEEE
- 1.6 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 85% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
